2003 Chevrolet Silvarado SS, Viper 4806V
flightrn
Member - Posts: 11
Posted: February 20, 2020 at 7:46 PM / IP Logged Link to Post Post Reply Quote flightrn
recommendations for bypass module/ interface/combo for this install. It has been a few years since my last install and there is too much information out there now. I do not want to mess with flashing. GMDLBP vs PKALL vs DB3? or others. This vehicle has a hard tonneau cover with a Dakota Digital actuated lift. Need 3 (-) output aux channels to raise /lower. Liked the Viper the best.
Platinum - Posts: 7,827
Posted: February 20, 2020 at 8:21 PM / IP Logged Link to Post Post Reply Quote kreg357
While you would have to hardwire the interconnections between the bypass module and the Viper, my vote goes for the Fortin INT-SL+. The INT-SL+ comes pre-flashed and is a solid performer. Here is a link to the Install Guide :
https://cdn02.fortin.ca/download/46281/int-sl+_revj.pdf
flightrn
Member - Posts: 11
Posted: February 21, 2020 at 9:59 PM / IP Logged Link to Post Post Reply Quote flightrn
thanks
will the int-sl+ trigger the heated seats and rear defrost?
Posted: February 22, 2020 at 5:06 AM / IP Logged Link to Post Post Reply Quote kreg357
Yes it will if the truck is equipped with those features. There is one gothcha.
Here is the note from the install guide :
Note : Heated seats will turn ON (low power) ONLY if the engine temp is below 0°C (32°F) when remote started.
flightrn
Member - Posts: 11
Posted: February 26, 2020 at 5:39 PM / IP Logged Link to Post Post Reply Quote flightrn
viper 4806v and int-sl+
int has a unlock driver 2 but viper does not.? will hitting unlock twice unlock both doors?
2003 ss has a 2nd accessory (brown) will this need to be energized by relay? (with the orange accessory +output)
Posted: February 26, 2020 at 8:57 PM / IP Logged Link to Post Post Reply Quote kreg357
Unlock Driver 1 and Unlock Driver 2 has to do with the trucks personalization settings. See Page 2-66 in the Owners Manual.
Basically, you will see a Driver 1 or Driver 2 message appear on the instrument cluster depending on which Factory FOB/remote you use to unlock the truck with.
The INT-SL+ will allow similar functions depending on the connections between the R/S and the bypass.
I personally power the Brown ACC2 wire during a R/S. It might not always be required but I try to duplicate a standard key start up with my R/S wiring.
You would need a 30/40 Amp SPDT relay controlled by the Vipers thin Orange (-) 200 mA ACC wire.
flightrn
Member - Posts: 11
Posted: March 02, 2020 at 2:02 PM / IP Logged Link to Post Post Reply Quote flightrn
awesome install thanks to your assistance. 3 Auxiliary functions run the tonneau cover amazingly well. Great range and everything works! saved $300 from what the local installer wanted.
