2002 Ford F250 Remote Start
muscle cars
Posted: June 24, 2002 at 10:30 AM / IP Logged
I will be installing is a Clifford Matrix RS2, Remote Start. Having a problem with the wait to start signal on a 2002 diesel. They say you can not do it because on 2002  the signal does not reach the light through a descrete wire. Instead, there is a serial data bus from the system controller to the warning light module that controls all of the lights, and the familiar BLACK/ pink wire does not exist.
Can any ony help
70' 442 Rag Top
Chris Luongo
Platinum - Posts: 3,746
Posted: June 24, 2002 at 10:21 PM / IP Logged
Techsoft says to get a pulse timer relay, and they list a document number on how to wire it up---I don't have access to that document though.
Essentially, you'd rig it up so that when the remote start first comes on, the timer relay sends a ground signal the the remote start's wait-to-start input, for a fixed amount of time, say, ten seconds.  After that ground goes away, the truck will start.
I still wonder if you could just pull out the cluster where that wait-to-start light is, and tap right into the bulb socket, and see if it's an ordinary 12-volt ground at that point.
Platinum - Posts: 12,488
Posted: June 24, 2002 at 10:41 PM / IP Logged
Ford
Pickup/F250 & F350
2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
GREEN
IGNITION SWITCH HARNESS
Ignition  #1:
RED / LT. GREEN
Ignition #2:
GRAY / YELLOW
Ignition  #3:
RED / BLACK
Accessory:
BLUE/LT.GREEN
Brake  Light:
LT. GREEN
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
SEE NOTE BELOW *
Parking Lights:
BROWN (+)
AT HEADLIGHT SWITCH
Headlights:
RED / YELLOW (+)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
OEM Alarm  Arm:
Diesel  Glow Plug:
PURPLE / ORANGE OR
WHITE/ LT. GREEN IN 42-PIN CONN. UNDER AIR FILTER BOX *
Clutch  Bypass Wire:
Notes:
 * For Tach On Gasoline Vehicles, Use Any Coil Wire That Is NOT RED / Lt. Green. For Diesel Vehicles, The Tach Wire Is Green And Can Be Found In A 42-Pin Connector Found Underneath The Air Filter Box. Remove The Air Filter Box To Access Wires.
Ford
Pickup/F250 & F350
2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
YELLOW
Starter  Kill:
GREEN
Ignition  +12 Volts:
RED / LT. GREEN
Dome  Lights/Superv:
BLACK/ LT. BLUE (-)
EITHER KICK PANEL
OEM Horn:
BLUE (-)
STEERING COLUMN HARNESS
Power  Lock:
SEE NOTE BELOW **
Power  Unlock:
SEE NOTE BELOW **
Trunk  Release:
N/A
Alarm  Input Wire:
BLACK/ LT. BLUE (-)
EITHER KICK PANEL
Notes:
** If Vehicle Is Equipped With Keyless Entry, Lock Is WHITE/ Red (-) And Unlock Is BLACK/ White (-). If The Vehicle Does NOT Have Keyless Entry, Then Lock Is Pink / YELLOW (5-Wire) And Unlock Is Pink/Green (5-Wire) Reverse Polarity Door Lock System. Use Driver's Door Switch When Testing.
Big Dog
Gold - Posts: 1,265
Posted: June 25, 2002 at 2:35 PM / IP Logged
Hey muscle cars,
First of all I'm only gonna share this with you cause you own one of the coolest muscle cars of the 70's!  I had a 71, 350 Rocket, 750 CFM, Hurst dual-Gate shifter, very expensive on tires but great memories!  But hey that's another forum.  You can't interface to the glow plug light in the dash so yes you do have to create a delay.  If it's an XLT Lariat then here's what I do.  While the key is on IGN, check to see if the radio comes on approximately when the glow plug light goes out.  If so then go to the back of the radio,  find a pink ignition wire and connect it to a relay to pin 86 and tie the pin 85 and pin 30 to ground. The wait to start wire of your remote starter goes to pin 87a.  And voila! You've just created a delay!  2002 Ford F250 Remote Start  -- posted image.
Prepare your future. It wasn't the lack of stones that killed the stone age.
muscle cars
Posted: July 08, 2002 at 12:15 AM / IP Logged
If your install goes wrong...it's guaranteed to be family!
Thanks Outstanding hook up. Yes Oldsmobile was the leader of muscle cars of the 70's.
I have the original engine with 325000 miles. Lots of money in rebuilding and tires. I just order the Good Year Raised Gold Letter: "GOOD YEAR EAGLE# 1 NASCAR" I am placing 60's in the front and 50's in the rear. I had to contact a friend in the Nascar circuit to get Goodyear to make the 50's, so I'm buying 4 of each.
Check them out:
http://www.goodyeartires.com/catalog/products/EAG1NAS.html
70' 442 Rag Top
