2010 Toyota RAV4 SRS Light On After Remote Start
youghta
Posted: August 06, 2020 at 8:57 AM / IP Logged Link to Post Post Reply Quote youghta
I recently installed an MPC Remote Start Kit in my 2010 Rav4 with key start (dot key) which includes a Crimestopper RS0 Add-on Remote Start and a Fortin Key-Override-All Data Bypass Module. All works just fine with one exception. If I remote start the car, the SRS light comes on and stays on even after I enter the car and turn the key to start. This does not happen if I start the car with the key. I've been working with MPC support and they have been very helpful, but I was wondering if anyone has seen this before or has any ideas. Thanks for your help!
geepherder
Platinum - Posts: 3,668
Posted: August 06, 2020 at 10:13 AM / IP Logged Link to Post Post Reply Quote geepherder
It sounds like there's another ignition wire that needs to get power. You should have both a pink and a white wire powered during remote start. You may need to use a relay if your system doesn't have another ignition output.
The light will likely stay on even after you do a key takeover until the ignition is cycled again.
youghta
Posted: August 06, 2020 at 10:28 AM / IP Logged Link to Post Post Reply Quote youghta
Thanks. The system does have two ignition wires, and they are connected to the pink and white as you have mentioned. I'll double check that both are good connections.
geepherder
Posted: August 06, 2020 at 1:11 PM / IP Logged Link to Post Post Reply Quote geepherder
You might want to meter them at the ignition harness during remote start, too. That way even if your connections are good, you'll know if you have a bad output.
youghta
Posted: August 06, 2020 at 2:14 PM / IP Logged Link to Post Post Reply Quote youghta
geepherder. Thanks for jumping in on this. You led me to the solution which is that the crimestopper was sending ACC to an IGN wire and the voltage was dropping to zero during crank instead of staying at 12V. A simple programming change resolved my issue.
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
