2011 Toyota Tacoma, Manual Transmission, Remote Start
monty_77
Copper - Posts: 491
Posted: November 01, 2020 at 7:43 PM / IP Logged Link to Post Post Reply Quote monty_77
Have not done a manual in a while, just wondering if on this vehicle if I can do starter wire to clutch instead of hooking up both starter wires 1 and 2. Or do I need to wire in relay for clutch switch and hook both up?
I see it a positive clutch that’s why I ask, i remember on older chevys I could just go to clutch instead
Platinum - Posts: 7,783
Posted: November 03, 2020 at 7:52 AM / IP Logged Link to Post Post Reply Quote kreg357
Yes, you are correct. Remember that the Tacoma has two Starter wires. On that truck you can power the Green/Black Starter1 wire as a normal Starter wire and then run a (+) Starter2 to the Black/Yellow wire at the Clutch Pedal instead of the Black/White Starter2 wire at the main ignition harness.
And, of course, use a proper Manual Transmission safe R/S unit. 2011 Toyota Tacoma, Manual Transmission, Remote Start - Last Post -- posted image.
Thursday, April 25, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
