Viper 5806V Alarm/Remote Start
itolond
Copper - Posts: 87
Posted: November 14, 2020 at 12:46 AM / IP Logged Link to Post Post Reply Quote itolond
Hi Have a Viper 5806v and it is its first power up. I have power to the unit (6pin 12VDC+), ground continuity confirmed, fuse is good.
I was attempting to pair the remote for the first time, however following the guide I get zero from th control centres- literally no lights/ nadda nothing at all - what can I check methodology. when the system is powered for the firs time i should be getting something?
lurch228
Silver - Posts: 1,338
Posted: November 14, 2020 at 2:11 AM / IP Logged Link to Post Post Reply Quote lurch228
All remotes shipped with the unit are already programmed to it. Only non supplied (add on) remotes need to be paired with the 5806v.
itolond
Copper - Posts: 87
Posted: November 14, 2020 at 3:01 AM / IP Logged Link to Post Post Reply Quote itolond
understand - but when i power the 5806V on i should get something right? (led beep, something?)
geepherder
Platinum - Posts: 3,668
Posted: November 14, 2020 at 3:41 AM / IP Logged Link to Post Post Reply Quote geepherder
No
itolond
Copper - Posts: 87
Posted: November 14, 2020 at 3:57 AM / IP Logged Link to Post Post Reply Quote itolond
then how can you tell its online - should i get led feedback from the control center?
geepherder
Posted: November 14, 2020 at 5:20 AM / IP Logged Link to Post Post Reply Quote geepherder
Hit a button on the remote and see if it works.
itolond
Copper - Posts: 87
Posted: November 14, 2020 at 7:17 AM / IP Logged Link to Post Post Reply Quote itolond
This may sound lame- but what am I looking for?
geepherder
Posted: November 14, 2020 at 9:08 AM / IP Logged Link to Post Post Reply Quote geepherder
Lock or unlock output and/or parking light output.
Also, if the 5806 is a two-way unit, you should get confirmation on your remote.
itolond
Copper - Posts: 87
Posted: November 14, 2020 at 9:23 AM / IP Logged Link to Post Post Reply Quote itolond
ill give this a try tomorrow an see what happens
itolond
Copper - Posts: 87
Posted: November 14, 2020 at 12:05 PM / IP Logged Link to Post Post Reply Quote itolond
on pressing arm (lock icon) it takes about 3-4 seconds then the orange led flashes 5 times and a tone - not a beep
Page of 4
