Viper 4105v, Flashlogic FLCAN, 2004 Chevrolet Silverado 1500
kylemack621
Posted: January 01, 2021 at 10:59 AM / IP Logged Link to Post Post Reply Quote kylemack621
Can anyone give me insight into this setup. I got the setup as a Christmas gift from my wife. It also includes a 8617 relay. This is my first attempt at a remote start. I’ve tried doing some research but I’m still kinda stumped on where to start exactly and show the remote start and bypass tie into each other. I am both mechanically and electronically competent. Just not on GM vehicles, more so aircraft. I have the wiring diagrams for both units and a wiring list for my truck. Any insight or help to get started would greatly be appreciated.
Kyle D Mack
Ween
Platinum - Posts: 1,368
Posted: January 01, 2021 at 12:16 PM / IP Logged Link to Post Post Reply Quote Ween
https://www.the12volt.com/installbay/forum_posts.asp?tid=133000 for a pictorial. The FLCAN has multiple ways of interfacing with the remote start module. Do you know if the FLCAN was 'flashed'? That will determine its wiring requirements.
kylemack621
Posted: January 01, 2021 at 12:40 PM / IP Logged Link to Post Post Reply Quote kylemack621
How would I know if it’s flashed? It was bought from crutchfield. I looked at that thread. Still having trouble wrapping my head around some of it. For example the hardwire vs data mode. How are the wires from the bypass to the remote start connecting? Depinning those were and soldering them together? Things like that.... I’m just trying to make sense of it all and find a solid place to start from.
Kyle D Mack
Ween
Posted: January 01, 2021 at 12:58 PM / IP Logged Link to Post Post Reply Quote Ween
May have to contact Crutchfield, ask if they flash them...maybe shows on the receipt. If flashed as hardwire, physical connections between the remote start and bypass need to be performed. if flashed as data, there's an interconnecting cable between the two modules, less connections between the two. Connections between the two modules can be done by soldering yes...or even crimp connectors/crimp caps.
kylemack621
Posted: January 14, 2021 at 7:32 AM / IP Logged Link to Post Post Reply Quote kylemack621
Ok I got this all wired up thanks to kreg357, and it works like a champ, but now I’ve noticed some type of battery draw while the truck is off. If it sits for more that 24 hrs I have to jump it off. Are there any common occurrences with remote start systems and this issue?
Kyle D Mack
geepherder
Platinum - Posts: 3,668
Posted: January 14, 2021 at 8:39 AM / IP Logged Link to Post Post Reply Quote geepherder
I'm curious, do you have anything connected to the ground-while-armed wire?
kylemack621
Posted: January 14, 2021 at 8:56 AM / IP Logged Link to Post Post Reply Quote kylemack621
I do not. I was instructed that the FLCAN would handle this function. I have the black wire from the 9pin harness and the black/white wire from the 5 pin harness of the viper connected to ground.
Kyle D Mack
catback
Silver - Posts: 703
Posted: January 14, 2021 at 10:53 AM / IP Logged Link to Post Post Reply Quote catback
Pull the fuse(s) for the Viper/FLCAN for 24 hours and see if your need to jump it go away. That or use an amp meter to find out how much amps it's pulling at rest.
lectricguy
Copper - Posts: 359
Posted: January 14, 2021 at 11:51 AM / IP Logged Link to Post Post Reply Quote lectricguy
Out of curiosity, did you add a relay to power the second accessory wire? If so, how did you wire the relay?
Lectric Guy
kylemack621
Posted: January 14, 2021 at 12:53 PM / IP Logged Link to Post Post Reply Quote kylemack621
I did install the second relay. Below is how everything was wired up per a fellow user on here:
Viper 4105
Main 9 Pin
1 LIGHT GREEN/BLACK FACTORY ALARM DISARM   *
2 GREEN/WHITE FACTORY REARM *
3 YELLOW (+) IGNITION OUT (TO ALARM)    *
4 WHITE/BLUE (-) ACTIVATION INPUT            *
5 ORANGE (-) GROUND WHEN LOCKED        *
6 BROWN (-) HORN OUTPUT          BLACK/YELLOW to BLACK (-)     @ STEERING COLUMN HARNESS
7 RED/WHITE (-) TRUNK RELEASE OUTPUT *
8 BLACK GROUND            Chassis Ground ( with Black/White Neutral Safety )
9 WHITE (+/-) LIGHT FLASH        set to (-)      GRAY/BLACK (-)     @ BCM, BROWN PLUG, PIN B2
R/S 5 Pin
1 BLACK/WHITE (-) NEUTRAL SAFETY SWITCH INPUT    Chassis Ground if Auto Trans
2 VIOLET/WHITE TACHOMETER INPUT WIRE     *
3 BROWN (+) BRAKE SWITCH SHUTDOWN WIRE             WHITE (+)     @ BRAKE PEDAL SWITCH
4 GRAY (-) HOOD PINSWITCH SHUTDOWN WIRE             to kit supplied hood pin switch
5 BLUE/WHITE (-) 200mA 2ND STATUS/REAR DEFOG          *
4-pin satellite harness diagram
1 BLUE STATUS OUTPUT    *
2 ORANGE (-) ACCESSORY OUTPUT              --> relay Pin 85 of ACC2 relay
3 PURPLE (-) STARTER OUTPUT       *
4 PINK (-) IGNITION OUTPUT            *
ACC2 relay
Pin 85 to ORANGE (-) ACCESSORY OUTPUT
Pin 30 to Brown ACC2 wire at ignition switch harness
Pin 86 and 87 to Red +12V constant
Pin 87a not used - insulate
Heavy gauge 6 Pin
1 RED (+) (30A) HIGH CURRENT 12V INPUT Red +12V constant
2 PINK/WHITE (+) PROGRAMMABLE set to IGN           White at main ignition switch harness
3 RED (+) (30A) HIGH CURRENT 12 INPUT     Red/White +12V constant
4 ORANGE (+) (30 AMP) OUTPUT TO ACCESSORY      Orange at main ignition switch harness
5 PURPLE (+) (30 AMP) OUTPUT TO STARTER             Yellow at main ignition switch harness
6 PINK (+) (30 AMP) OUTPUT TO IGNITION   Pink at main ignition switch harness
Door lock harness, 3-pin connector
1 BLUE (-) UNLOCK OUTPUT           *
2 EMPTY NOT USED           *
3 GREEN (-) LOCK OUTPUT              *
* = not used or handled by FLCAN and D2D harness
D2D port to FLCAN DATA port
FLCAN wires
DATA port to 4105 D2D port
Orange wire to truck OBD2 Violet at Pin 2
Pink to 4105 thick Pink IGN1 ( which goes to truck Pink IGN1 )
Kyle D Mack
