Avital 4115L Remote Start, 2013 Ram 1500
seebuzzlol4
Posted: February 06, 2021 at 2:07 AM / IP Logged Link to Post Post Reply Quote seebuzzlol4
looking for help installing this avital 4115L in 2013 dodge ram 1500 4+4
2934 judith rd
Platinum - Posts: 7,828
Posted: February 06, 2021 at 7:03 AM / IP Logged Link to Post Post Reply Quote kreg357
What type of "help"?
You mention the Avital 4115L R/S unit but no bypass module. Do you have a bypass module?
Does your truck have a key or Push-to-Start ignition system? Auto trans or Manual trans?
Have you looked at this Pictorial on a 2013 RAM 1500?     https://www.the12volt.com/installbay/forum_posts.asp?tid=138747
It uses a different R/S unit and bypass module but the wire info is accurate.
seebuzzlol4
Posted: February 06, 2021 at 8:10 PM / IP Logged Link to Post Post Reply Quote seebuzzlol4
i only bought remote starter and truck a week ago 2013 it has smart key not push button was looking for wire diagram or service repair manual for the ram.guess i need to also find out if bypass module is required
2934 judith rd
Posted: February 06, 2021 at 8:27 PM / IP Logged Link to Post Post Reply Quote kreg357
Pretty sure a bypass module is required if you have the TIP-Start system.
Here is a link to the iDatalink ADS AL-CA bypass module with the DBI CH8 firmware for your truck. This DBI firmware will interface with you Avital R/S unit. The Type 3 diagram is used. https://images.idatalink.com/corporate/Content/Manuals/DL-CH8/DBI-AL(DL)-CH8-EN_20191004.pdf
There are other bypass modules available and all need to flashed with the specific firmware for your vehicle.
seebuzzlol4
Posted: February 07, 2021 at 5:51 AM / IP Logged Link to Post Post Reply Quote seebuzzlol4
thanks kreig i will check link you gave me
2934 judith rd
Thursday, February 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
