Easyguard EC200-K9 Alarm Manual
bradshaw1080
Posted: September 12, 2021 at 2:51 AM / IP Logged Link to Post Post Reply Quote bradshaw1080
Please help , in need of any install info or docs on a easygaurd EC200-K9 any 8nfo will be very appreciated thanks 93 Mercury cougar xr7
Brad beringer
Platinum - Posts: 13,726
Posted: September 12, 2021 at 3:48 PM / IP Logged Link to Post Post Reply Quote i am an idiot
12 Volts      black/orange      +      ignition harness
Ground      (chassis ground)
Starter      red/lt. blue      +      ignition harness
Ignition      red/lt. green      +      ignition harness
Accessory      gray/yellow      +      ignition harness
Power Lock      pink/yellow           drivers kick panel           Notes
Power Unlock      pink/green           drivers kick panel           Notes
Factory Alarm Disarm      dk. green/violet      -      either kick panel
Parking Lights      brown           at switch or fuse box
Headlight      red/yellow      +      at light switch
Left Front Door Trigger      black/lt. blue      +      under dash light
Trunk/Hatch Release      violet/yellow      +      switch
Tachometer      tan/yel or      AC      see notes           Notes
Brake Wire      lt. green      +      at brake pedal switch
Horn Trigger      yellow/lt. green      -      at steering column
Wipers      brown/white      +      wiper switch
Left Front Window (Up/Down)      wht/blk - yellow      A      in drivers door
Right Front Window (Up/Down)      tan/blk - wht/yel      A      in drivers door or dkp
