Starter Kill Relay on Viper 5806v
artistwantab
Member - Posts: 15
Posted: November 02, 2021 at 5:26 PM / IP Logged Link to Post Post Reply Quote artistwantab
Hey guys
I am new here.
I am in the process of installing my Viper 5806v on my (new) 2005 Sprinter.   This is the first canbus electrical system...
So here is the wiring diagram from the site.
Starter Kill Relay on Viper 5806v - Last Post -- posted image.
Seems pretty clear but what amp relay do I use?
Platinum - Posts: 7,827
Posted: November 02, 2021 at 7:44 PM / IP Logged Link to Post Post Reply Quote kreg357
Good news! Your Viper 5806 has built in Starter Kill. Just use the thick Green and Violet wires on the 10 Pin Remote Start plug. No need for an external relay. This will also provide an Anti-Grind feature if needed.
Cut the vehicles Black/Yellow Starter wire and connect the Green and Violet Viper wires as per the instructions.
artistwantab
Member - Posts: 15
Posted: November 02, 2021 at 8:44 PM / IP Logged Link to Post Post Reply Quote artistwantab
Thank you!
Hmmm..
Then what is the h1/6 Orange (-) 500ma Ground When Armed Output?
2005 Mercedes Sprinter
Posted: November 03, 2021 at 4:40 AM / IP Logged Link to Post Post Reply Quote kreg357
While it could be used for that purpose
( with special wiring to prevent battery drain ), typically that wire is used to trigger "window rollup" or similar operation.
Being as your highend Viper has Starter Kill already built in it's easier to do it that way. There will be quite a few unused wires on the Viper system.
artistwantab
Member - Posts: 15
Posted: November 03, 2021 at 5:17 PM / IP Logged Link to Post Post Reply Quote artistwantab
@kreg357
Thank you for the reply.   It is greatly appreciated.
OK. So now I like the window roll-up option.
Do I need two 529T Power Window Roll Up Modules?   One for each side?
artistwantab
Member - Posts: 15
Posted: November 03, 2021 at 9:07 PM / IP Logged Link to Post Post Reply Quote artistwantab
One more question I know I am a noob but I want to learn this.
So I am wiring the door locks...I don't have a door relay? My door locks are controlled by the CTM.
Do I need the 451m Door Look Relay?
This is from the sprinter wiring manual.
I would like to unlock all doors.
Thanks for the help.
Posted: November 04, 2021 at 3:09 AM / IP Logged Link to Post Post Reply Quote kreg357
"OK. So now I like the window roll-up option.
The 529T will handle two windows in one direction, so yes, the 529T can do window roll-up on both front door windows.
There is a 529T Install Guide in the downloads section.
Posted: November 04, 2021 at 3:29 AM / IP Logged Link to Post Post Reply Quote kreg357
"So I am wiring the door locks...I don't have a door relay? My door locks are controlled by the CTM.
The simple / easy way to handle the door locks is by using one wire that causes the locks to lock with a pulse and then unlock with the next pulse, alternating back and forth.
Lock............WHITE/YELLOW..................AT SWITCH ON DASH OR CTM PINK PLUG, PIN 7......NEGATIVE PULSE ALTERNATES
Unlock..........WHITE/YELLOW..................same wire
If you want to ensure a FOB Lock press/command locks the Sprinter, and a FOB Unlock press/command unlocks the vehicle, then buy three 30/40 Amp SPDT relays with 5 wire harnesses and follow DEI Teck Tip 1700, link below :
https://www.the12volt.com/installbay/file.asp?ID=490
artistwantab
Member - Posts: 15
Posted: November 04, 2021 at 5:34 PM / IP Logged Link to Post Post Reply Quote artistwantab
@kreg357
Thank you SOOOO much!
I didn't even know about that section of the site. I was also able to fine the N5x06 installation manual which makes things to much clearer. I have been using the quick installation guide given by Viper this whole time.
Thanks again.
Be back when I hit a road block.
artistwantab
Member - Posts: 15
Posted: November 05, 2021 at 2:18 PM / IP Logged Link to Post Post Reply Quote artistwantab
507M install Questions...Is this correct and
507m Wiring
Red
Connected to constant 12v Power Source - Should I add a fuse?
Orange
H2 Orange     (-)200mA Accessory output
Blue?
Can I connect this to the grey/yellow trunk trigger since I do not have a trunk?
Wednesday, July 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
