5 Wire Central Locking Issue
itskv
Posted: April 26, 2023 at 1:33 PM / IP Logged Link to Post Post Reply Quote itskv
I have a 5-wire door actuator and a central locking box. I do have a Viper 5706v - blue/green to spare white/brown on the control box harness.
I have my actuators set up for reverse push/pull, Blue/Green & White/Brown are swapped at the actuator.
The system has been working for a few years and recently stopped responding (clicking is still heard from the box). Found out that some of the wiring on the harness at the actuator door was an issue and made new terminal connections there.
With the new terminals, now the actuator only responds to lock, but not unlock - vice versa if I flip the blue/green & white/brown. I put a voltmeter on the box harness side and can see ~6v to 7v when I unlock/lock at the blue/green pin on the harness connector. Could this be an issue? (the actuators do respond to lock or unlock depending on the wiring)
I've tried:
new 5-wire actuator - same issue, no change
new control box, same issue, no change
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
