Remote Start Problems
blkjava
Member - Posts: 18
Posted: June 20, 2003 at 9:47 AM / IP Logged
I have a 1999 Lincoln Navigator I just completed  an installation of a CrimeStopper CS-2011RS Series 111 with remote start. The problem is  the remote start  will turn-over the engine but will not start  and run I went  to a dealer they told me I have to buy a new for $400.00 to be placed in the brain of the alarm for it to work because my keys have a security chip that the computer have to read before my truck can starts....Any advise?
A sabato
Moderator - Posts: 12,488
Posted: June 20, 2003 at 9:52 AM / IP Logged
They are full of it !! You can purchase a byapss module that will take care of the problem for about $ 40.00 and you do not loose a key out of the deal either. You do need two active keys to program the module though.
blkjava
Member - Posts: 18
Posted: June 21, 2003 at 12:25 PM / IP Logged
  I found under my dash a  universal bypass module DEI 555U with a key inside the problem is the wires are all disconnected how do i reinstall this unite......Wire colors. 2 pin socket (1black 1blk-white) next a 3 pin socket (wire color......Red,Blue, and White
A sabato
Posted: June 21, 2003 at 3:53 PM / IP Logged
RED wire goes to constant. BLUE wire is your negative out from alarm . WHITE wire is not needed & the plug for the ring that goes around the steering column plugs into the 2 pin socket.
blkjava
Member - Posts: 18
Posted: June 21, 2003 at 6:04 PM / IP Logged
Thanks Jeff .... Your help is well acknowledge
A sabato
Posted: June 22, 2003 at 8:45 AM / IP Logged
No problemo.
blkjava
Member - Posts: 18
Posted: June 22, 2003 at 10:03 AM / IP Logged
No problemo.
Hey Jeff I made the connections as you stated.... The truck starts up and idle but i can still hear the starter running and the security light comes on and then it shuts off....Problem #2 the remote no longer open-n-closed the doors....the park lights stop flashing....
A sabato
Posted: June 22, 2003 at 11:00 AM / IP Logged
Did you connect up all the necessary ignition iwres ?
IGNITION|blue/lt. green      |+  |ignition harness            |
|  SECOND IGNITION|gray / YELLOW(2nd acc)|+  |ignition harness            |
|        ACCESSORY|RED / black           |+  |ignition harness            |
| SECOND ACCESSORY|BLACK/ green         |+  |ignition harness            |
Also, make sure that the tach wire is programmed to the vehicle. If the starter is dragging, chances are the installer's never programmed the tach wire to the Lincoln.
blkjava
Member - Posts: 18
Posted: June 22, 2003 at 4:08 PM / IP Logged
Ok....  ?do I have to connect a relay to each Ignition .....because i connect a relay and now the security light is off...the sound like when you have a weak battery and just will not turn-over.... Relay Connections  i did its was pre-wired... yellow connect to orange wire from alarm........Blue wire connect to IGN #1.....then i cut the starter wire connect one end.... Orange to starter wire from IGN ......other Orange to Starter Wire...
A sabato
Posted: June 22, 2003 at 5:35 PM / IP Logged
Both IGN wires have to be connected in order for the RS to work properly. If the RS has a (+) output second IGN wire then all you need to do is hook it straight up to the 2nd igntion wire. If it's a (-) for a relay then you need to use the relay diagram above, but only for the second ignition wire. The primary ignition wire is already a (+) output.. Also, make sure that you learn the tach.
Thursday, November 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
