Bad Distortion
clftn
Member - Posts: 9
Posted: June 27, 2003 at 10:12 PM / IP Logged
I just installed a Clarion DVD headunit and 2 sets of JL Audio speakers. The headunit had a separate amp with 18x4 watts rms.  When I turn it up anymore than halfway the speakers get heavily distorted and sometimes make a popping sound. I have heard this could be caused by underpowering but I'm not sure. Also, is it possible the distortion could be coming from the power supply? The power cable is within a foot or so of the wiring harness. Any advice would be greatly appreciated.
esmith69
Gold - Posts: 1,511
Posted: June 27, 2003 at 10:15 PM / IP Logged
No the distortion is not coming from the power cable.  The power cable itself may be too small, but I think that's not what's causing your problem.  Just an overall lack of sufficient amplifier power is what's the problem.  Only thing I can suggest is that if you want it up that loud you'll have to turn down the bass and treble a little bit.  Or get an external 4-channel amplifier.
Ethan
Donate to the12volt.com
