bass reflex tubes
skipastaria
Member - Posts: 18
Posted: June 28, 2003 at 2:07 PM / IP Logged
i have a dual voice coil volfenhag 12" speaker in a 1.87 square foot box and need to know what diameter bass port and length of port tube is needed for the correct sound it only says the size of port o must be a maximum of 10% of port 1 length
chevylove
Copper - Posts: 51
Posted: June 28, 2003 at 2:36 PM / IP Logged
You'll need a 1 1/2" diameter port at roughly 6 3/8" long.  If you want to use a 1" port it's going to need to be about 11 1/2" long.
Drew   "Fuses are only 10 cents...go for it."
skipastaria
Member - Posts: 18
Posted: June 28, 2003 at 2:50 PM / IP Logged
what about a 3" tube what would be the length
chevylove
Copper - Posts: 51
Posted: June 29, 2003 at 9:50 PM / IP Logged
First off scratch the first two numbers I gave you.....i must not have been in my right mind that day.  For a 3" tube you'll want about 11 1/4".
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
