Compustar AS remote start with Preluber delay
Ranger5.?
Posted: June 28, 2002 at 9:25 AM / IP Logged
I have the compustar AS controller and I want to install the remote start on it.  One problem,  When I turn my key to the run position I need to leave it there for 30 sec while my preluber primes the engine.  Is there a way to incorporate this into the Compustar system.  The install manual leaves much to be desired in examples or even descriptions to explain if a wire is an input or output, at least with the AS controller guide.  I could maybe do something with an accessory out??  Any info would be appreciated.
Thanks,
Carpy
Moderator - Posts: 12,488
Posted: June 28, 2002 at 1:20 PM / IP Logged
I'm not sure if the Compustar has this option available to delay the timing from ignition to crank. I know the Aladdin a-2000 has variable timing for such an option up to 20 seconds. Check with the manufacturer on this and see if they have a programming upgrade for this type of feature.
Ranger5.?
Posted: June 28, 2002 at 4:35 PM / IP Logged
Thanks for the info.  Their manual is so vague and their email tech support  is no gazelle.  I haven't dug deep enough into the logic but I wonder if it would be possible to start the preluber by using an aux. output from the controller.  If not I will try and get a hold of these guys.
Thanks again,
Carpy
Saturday, October 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
