2002 Honda Civic EX Coupe stereo wiring
jjschoen
Posted: July 22, 2003 at 12:58 AM / IP Logged
Help! I recently purchased a 2002 Honda Civic EX Coupe. The previous owner cut off the factory connector to the in dash cd player. I guess the moron didn't realize adapters exist! I have installed a sony cd player with the metra mounting kit, and I have detemined all the wiring except the constant 12 volt wire. What color is it! I have found several wiring diagrams for my car on the web, but they are all inaccurate! Here are the wires left to choose from:
Yellow w/ green stripe
White w/ red stripe
Red w/ black stripe
Red
Any help from someone with experience on the 2002 civic would be appreciated. I guess they changed the colors from 2001. Thanks.
esmith69
Gold - Posts: 1,511
Posted: July 22, 2003 at 10:00 PM / IP Logged
the constant power wire should be the white w/red stripe wire;  also it should be slightly thicker than the other wires except for the ground wire.
the red w/black stripe is the illumination, and the red is the dimmer.  I recommend you not make those connections though unless you really really really want to have that feature on your head unit (and remember many don't even use that).
Ethan
Donate to the12volt.com
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
