Rear View Mirror Vibration
pc_man83
Member - Posts: 8
Posted: July 23, 2003 at 6:39 AM / IP Logged
Hi,
I have a 1998 Sunfire coupe.  I have a 12" rockford dvc and a mtx 1502, I know this is old but it sounds great.  Now when the bass hits my rear view mirror really vibrates.  If i pull down a bit or just rest my finger on any part of it, it stops vibrating.  Anyone know about fixes to this problem.
Mike
cpgoose
Gold - Posts: 1,098
Posted: July 23, 2003 at 7:05 AM / IP Logged
That's a good thing....the mirror lets you know that the sub is working Rear View Mirror Vibration -- posted image.
Seriously, in my old car, where the mirror was attached to the windshield, it actually fell off a few times due to heat and sub vibration. In my car now, the mirror comes down from the roof, so it's more stable. I'm not sure, maybe you can put a weight on it of some sort. Just be careful that it doesn't pull it down off the window.
Q: What's the best nation in the world?
A: Donation!     Donate to the12volt.com
acq810z
Member - Posts: 32
Posted: July 23, 2003 at 4:45 PM / IP Logged
there is a easy way to elievate it.....in some cars there is a rubber stop that fits between the arm for the mirror and the windshield.....usually about 1 inch long.  it will cut down the vibrations but not get rid of them. just go to a home improvement store and look around some thick walled black stiff (but with a little give, kinda like a pencil eraser) and buy a few inches (1 or 2) then you want to cut the tube just a little long so that it wedges between the mirror and the glass (but not overly tight, just snug)  This will act as a shock absorber and cut down on the vibrations.......
i have seen this in some of the cars, amazingly the manufacturers do this.
Hope this helps
~Q
Friday, January 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
