siren
Cros
Member - Posts: 6
Posted: July 03, 2002 at 2:22 PM / IP Logged
I HAVE A 500 ESP VIPER ALARM AND THE SIREN STOP WORKING. ALL THE SENSORS WORK AND THE LIGHTS FLASH WHEN THE ALARM GOES OFF. I CHECKED THE RED WIRE TO THE SIREN AND IT WAS GETTING POWER .I THINK THE SIREN IS BURNT OUT BUT HOW CAN I TELL.  CAN I PUT ANY SIREN OR DOES IT HAVE TO BE THEONE THAT IT CAME WITH?
HELP WOULD BE APPRECIATED
GlassWolf
Copper - Posts: 365
Posted: July 03, 2002 at 2:49 PM / IP Logged
you should be able to replace that siren with any standard alarm siren that takes a +12V output from the alarm's BCM.
good luck!
The sirens do die sometimes.. they are always exposed to the elements being up under the hood and exposed to a lot of heat too.. it happens now and then.
-GlassWolf
Pioneer Stage-4, Orion, DynAudio, Fi
Platinum - Posts: 12,488
Posted: July 03, 2002 at 3:49 PM / IP Logged
Make sure you check to see if the siren is still grounded before you start taking things apart.
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
