95 Jetta
ajb088
Member - Posts: 8
Posted: July 31, 2003 at 8:51 PM / IP Logged
I'm preparing to install a Clifford Avant Guard 4 in a 95 VW Jetta. I work at an auction yard where we sell alot of these cars (400+ a month). I never see aftermarket alarms in these cars, is this because there is problems as a result? I know aftermarket accessories can cause problems with the immobilizer equipped models (99+), but havent seen problems with models of this year. Any input would be appreciated.
Moderator - Posts: 12,488
Posted: July 31, 2003 at 9:06 PM / IP Logged
The vehicle is basic with no real problems with electrical wiring for aftermarket accessories. Here is the wiring datasheet for this car and as you can see, it's a basic system without too many bypasses:
|              12V|red          10  ga.|+  |ign. harness - big          |
|          STARTER|RED / black     10 ga.|+  |loop at back of             |
|         IGNITION|black         16 ga.|+  |fuse box                    |
|  SECOND IGNITION|*8                  |   |                            |
|        ACCESSORY|BLACK / YELLOW  12 ga.|+  |                            |
|       POWER LOCK|yellow/red or gray  |+  |driver door harness in kick |
|     POWER UNLOCK|RED / blk or green *2 |+  |driver door harness in kick |
| PARKING LIGHTS +|gray/red, gray/black|   |back of lt.switch *3        |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|WHITE/ black         |+  |back of light switch        |
|     DOOR TRIGGER|BROWN / white         |-  |dr. kick or alarm mod *7    |
|  TRUNK/HATCH PIN|BROWN / black         |-  |dr. kick or alarm mod *7    |
|         HOOD PIN|BROWN / red           |-  |behind fuse box             |
|TRNK/HTCH RELEASE|gray *4             |   |switch                      |
|  FCTRY ALARM ARM|same as lock        |+  |                            |
|FCTRY ALRM DISARM|same as unlock *5   |+  |                            |
|       TACHOMETER|*1                  |   |*1                          |
|       BRAKE WIRE|RED / black           |+  |brake pedal switch          |
|     HORN TRIGGER|BLACK / YELLOW        |+  |behind fuse box             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|not recommended *6  |   |                            |
|  RF WINDOW UP/DN|not recommended *6  |   |                            |
|  LR WINDOW UP/DN|not recommended *6  |   |                            |
|  RR WINDOW UP/DN|not recommended *6  |   |                            |
Notes:
*1 On the 4 cylinder model find a green at the coil on the firewall.  The VR6 has a BLACK/ purple at the coil pack.  The coil pack is located on the right side of the motor towards the front.  *2 Requires a double pulse to unlock.  *3 Hidden release tab for light switch on upper left side of switch.  Use relays to isolate the switch side of parking light wires from seeing 12v, or the igniton circuit will pulse with the light flash.  It is also possible to use the hazard lights.  The colors are BLACK/ white and BLACK/ green, and are positive trigger.  They can be found at the alarm module or steering column.  *4 Gray wire grounded by switch at rest. Use a relay to isolate the switch side of the trunk release wire from seeing 12v.  *5 Use a single pulse to disarm without unlocking.  *6 Each power window motor is controlled by a module, the module and the window motor are built together as one piece, not allowing access to the motor wires  *7 The alarm module is located behind the headlight switch.   *8 There is a positive trigger key sense wire at the ignition switch or in the radio harness.  The wire color is BROWN / red.
Wednesday, July 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
