'01 maxima push button ignition
unknown user
Posted: August 03, 2003 at 11:13 AM / IP Logged
2001 maxima se
Here’s the wiring diagram
|              12V|                      |   green                         |      | + |          ignition harness            |
|          STARTER   |             | BLACK/ red or blk/wht     |      | + |          ignition harness            |
|   SECOND STARTER|      |    BLACK/ blue                 |      | + |          ignition harness            |
|        IGNITION|                 | BLACK/ red (smaller)       |      | + |          ignition harness            |
|        ACCESSORY|            | RED / yellow                    |      | + |           ignition harness            |
| SECOND ACCESSORY| | WHITE/ blue                    |      | + |             ignition harness           |
|       POWER LOCK|           | gray                            |      | - |        pin 23 at SECU *1           |
|     POWER UNLOCK|        | BROWN / yel                    |     | - |        pin 35 at SECU *1           |
|       LOCK MOTOR|            | purple                         |     |     |        pin 15 at SECU *1           |
|     UNLOCK MOTOR|        | WHITE/ black                 |     |     |        pin 13 at SECU *1           |
|    DISARM DEFEAT|          | GREEN/ YELLOW               |     |     |        pin 14 at SECU *1           |
| PARKING LIGHTS +|        | RED / blue                      |     |     |           driver kick panel *2        |
| PARKING LIGHTS -|          | lt. blue                        |     |     |             headlight switch            |
|       HEADLIGHTS|             | pink                            |     | - |             headlight relay *7          |
|     DOOR TRIGGER|          | *3                               |     |     |               SECU *1                     |
| DOME SUPERVISION|      | use door trigger        |     |     |                                                  |
| TRUNK/HATCH PIN|        | purple / YELLOW              |     | - |          pin 38 at SECU *1           |
NOTE: This vehicle has an immobilizer system that needs to be bypassed during remote start operation.
*1 The SECU (Smart Entrance Control Unit) is located to the      passenger’s side of the steering column
*2 can also find RED / green or RED / yellow at fuse box
Ok
What I am trying to do is set it up so that I can start the motor with a push button switch.
Let me go more into detail
You put the key into the ignition and you turn it to run ( notice I said run not start) then you push this button and the motor starts.
So here’s what I did
I hooked up to the secondary accessory line so the car is only startable when the key is in the starter. Put a 12v fuse in there for protection. Then the switch it was rated for 12v and was labeled for push button ignition so I didn't feel I needed to use a relay. Then I wired to the starter line. Tried it and nothing. So I tied together both starter lines and still nothing.
I grabbed the manual checked what points had continuity between them on the leads on the ignition module. There was continuity between the 12v, starter1, starter2, and ignition. So then I grabbed power from the 12v and wire the push button switch to starter 1, 2, and ignition.
After I reconnected the battery I tried it once again and nothing happened. So I’m out of ideas.
Does and one have an idea ?
Platinum - Posts: 12,488
Posted: August 03, 2003 at 11:17 AM / IP Logged
Check this link out for more information:
https://www.the12volt.com/installbay/forum_posts.asp?tid=16973&tpn=1
Posted: August 03, 2003 at 11:18 AM / IP Logged
Also, you will need to cut both starter wires in order for this to work
