Thunderbird help
undergraduate
Member - Posts: 9
Posted: August 07, 2003 at 12:31 AM / IP Logged
I need some help with a 1997 Ford Thunderbird.  I am in the process of installing a remote start/alarm on this car and I have conflicting information.  What type door locks/unlock does it have and what are the wires?  And what/where is the tach wire?  Thanks.
draasch
Gold - Posts: 2,172
Posted: August 07, 2003 at 4:42 AM / IP Logged
Make:   Ford
Model: Thunderbird
Year:    1997
This Database Was Last Updated On:    6/9/03
Index #: 790
Alarm
Constant 12 volts BLACK/ ORANGE (5) IGNITION SWITCH HARNESS
Ignition 12 volts RED / L GREEN IGNITION SWITCH HARNESS
Starter RED / L BLUE IGNITION SWITCH HARNESS
Dome Light BLACK/ L BLUE (+) WHITE 36 PIN CONN. BEHIND DR. DASH *
Trunk Pin Switch N/A MERCURY TILT SWITCH
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH **
Power Lock PINK / YELLOW PASSENGER KICK #203
Power Unlock PINK/L GREEN PANEL *** #201
* White 36 Pin Connector Located Behind Driver Dash To Left Of Steering Column. ** BROWN (+) Wire ALso Located In Natural 6 Pin Connector Behind Driver Dash To Left Of Steering Column. *** Without OEM Keyless Entry Door Locks MUST Be Tested From Passenger Switch!! Without OEM Keyless See Note #203, With OEM Keyless See Note #201
#201- See Negative Pulse Door Lock Diagram. #203- See Reversal Rest At Ground Door Lock Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
undergraduate
Member - Posts: 9
Posted: August 07, 2003 at 1:08 PM / IP Logged
If I measure the voltage on the pink/green unlock wire to ground it reads nothing, how could it be negative pulse lock?  And, I still need the tach wire.  Thanks.
profuse007
Gold - Posts: 2,015
Posted: August 07, 2003 at 2:23 PM / IP Logged
true, but have you try flipping the door lock switch while testing it?
note: Some models of this vehicle are equipped with PATS (Passive Anti Theft System). Use DEI module 555F to over-ride during remote start.
TACHOMETER|blue/green          |   |coil pack
Houston,TX
undergraduate
Member - Posts: 9
Posted: August 07, 2003 at 2:40 PM / IP Logged
Yeah, when you hit the switch, both the lock and unlock wires show positive 12 volts for about 3 seconds.
Also, is there anywhere inside the car I can get the tach from?
draasch
Gold - Posts: 2,172
Posted: August 08, 2003 at 7:14 AM / IP Logged
does the car have a factory keyless entry???
if so you have a neg system. if not you need to use the 5 wire rev. polarity
Good Luck
David
Ace Security
813-376-9778
Tampa
