Central locking disabled by alarm?
ewpurdy
Posted: August 07, 2003 at 11:30 AM / IP Logged
I have a Commando 2 door central locking system installed and working fine.
When I connect the lock/unlock outputs of my alarm to the inputs on the central locking module, the central locking stops working.  I can lock or unlock both doors with the alarm but cannot lock one door with the other.  Furthermore, if the 2 locks are in opposite positions, then the alarm won't lock or unlock the doors at all.  Is this normal?
Does a 5 wire actuator act just like a 2 wire actuator if you ground the other 3 leads?
Thanks for the help.
elrayodesinaloa
Copper - Posts: 120
Posted: August 07, 2003 at 6:46 PM / IP Logged
diode isolate them see what happens.
