Help 1991 Mazda Navajo
Black Lightning
Posted: August 10, 2003 at 12:33 PM / IP Logged
Hi I have a 1991 Mazda Navajo and am trying to install a remote start but the info that I got off of here says there is a  1 starter output wire and it is pink but I have 2 what one do I go to I tryed one but it did not start??? please help
Platinum - Posts: 12,488
Posted: August 10, 2003 at 12:41 PM / IP Logged
Use your DMM to test for this wire. If the DMM register's voltage when you start on this wire, you have the right one.
Black Lightning
Posted: August 10, 2003 at 4:02 PM / IP Logged
I did that and they both have voltage when I Start it and they both are pink. I tryed both fo them with no luck I got it to the point were if I try to start it every thing goes as it should but it will not start please help
Posted: August 10, 2003 at 4:05 PM / IP Logged
My notes tell me that you only need one, but if both are needed for startinf, you will need a relay to engage the second starter wire. Use this diagram: http://www.velocitymotorsport.com/images/install_notes/108.jpg
Black Lightning
Posted: August 10, 2003 at 7:27 PM / IP Logged
there is 3 wires look at the install manual here but what you are saying is not to put these wires together like thisHelp 1991 Mazda Navajo -- posted image.
Black Lightning
Posted: August 12, 2003 at 10:09 AM / IP Logged
ttt
