Ford Clutch Bypass
Steve #1
Member - Posts: 35
Posted: July 06, 2002 at 10:20 PM / IP Logged
Howdy guys,
  I'm installing a Clifford AG4 in my wife's 2002 Explorer SportTrac.  I'm having a hard time figuring out the clutch switch.  The slide switch has six wires going to it and has contacts at the top which I assume are for the speed control, and two different contacts at the bottom for the starter, but I still can't figure out which wires to jump for the bypass.
Any help would be appreciated.
   Thanks, Steve
DeathsJester12V
Silver - Posts: 352
Posted: July 24, 2002 at 12:41 AM / IP Logged
Please tell me this ain't for a remote start!!!  Please!!!!
if it is, you might wanna check you local laws, but as far as I know, most states Say its illegal to install a remote start in a manual transmission, which last time I checked this is the only reason you'd need a Clutch by-pass....Reason...people forgetting its in gear, trying to start the car, and running a kid over...IT HAS HAPPENED!!!
Đễẳ†ђş 12\/ Ĵęśŧē®™
TheRapture
Copper - Posts: 208
Posted: July 24, 2002 at 11:30 AM / IP Logged
glue the switch down so it thinks the clutch is in allll the time Ford Clutch Bypass -- posted image.
omegamotorsprts
Member - Posts: 18
Posted: July 24, 2002 at 9:54 PM / IP Logged
I'm pretty sure you could glue it down, and it would work, but it'd be best to find the wiring, IMHO, I only had a two wires coming from a switch under my clutch, so it was pretty obvious I just had to cut and crimp, but I'd use your multimeter and go through testing what gets voltage with switches in or out,etc.. or if it works that way, I don't know I haven't seen that care.
niloc
Member - Posts: 7
Posted: October 30, 2002 at 12:10 AM / IP Logged
DeathsJester12V, calm down, the AG4 has safty feature called SafeStart, which legaly allows you to use remotes start without posing  any kind of threat.
LaterDays
Posted: November 06, 2002 at 5:59 PM / IP Logged
Steve #1,
I've got the Exact same question for the same vehicle.  I was wondering if you figured it out.
Or if anyone else knows the answer to this delima just post.
Thanx,
Laters!
Steve #1
Member - Posts: 35
Posted: November 07, 2002 at 12:52 AM / IP Logged
Yes, you'll need to jump the PINK to the PINK/WHITE.  Bottom two wires on the plug.
LaterDays
Posted: November 07, 2002 at 2:56 AM / IP Logged
Thanx.Ford Clutch Bypass -- posted image.
Grslc
Posted: November 20, 2002 at 3:44 PM / IP Logged
How does this safestart feature work?
Corrado SLC
Player69
Silver - Posts: 504
Posted: November 20, 2002 at 7:17 PM / IP Logged
Grslc, most manual transmission remote starts use this feature.  How it works:  You have to first put the car in neutral then apply the park brake.  After that you turn the remote start on and shut the key off.  The remote start will stay running and you then leave the vehicle.  At that point you shut the remote start off and lock the doors.  If the door is opened before the next time you attempt to remote start, the car will not start.
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
