Brake Problem?
Outlawz
Member - Posts: 33
Posted: August 18, 2003 at 6:16 AM / IP Logged
i am wonderinf if anyone could help me with a problem that i have....i am currently working on a 1994 Acura Integra LS and i am installing an alarm.....my problem is that the brake lights don't work, i tested it at the brake switch with a test light and i get no power at all....can anyone please help.
thankyou
bberman1
Gold - Posts: 2,314
Posted: August 18, 2003 at 11:10 PM / IP Logged
start by checking the fuses
JamesRH
Copper - Posts: 102
Posted: August 19, 2003 at 12:32 AM / IP Logged
94 acura....ive seen similar probelms with acuras of that time period....your ignition might be dying...somehow almost everything has to go through there on those cars....the brakes might too
brianh
Silver - Posts: 518
Posted: August 22, 2003 at 6:59 PM / IP Logged
Every time I have installed a R.S unit on a honda/Acura and had to tap the brake wire for the shutdown feature I have had trouble. For one they are a pain to get to. Also it looks like the top of the switch just pulls up and off but the real connector to unplug it is at the bottom. If you pull on the top and pull it loose just a little the brake switch will not work. Make sure that the top is snapped down well. Good luck with it!
Brian
owner/installer
Sight & Sound Car Stereo
"all electronic equipment runs off of smoke, once you let it out, it stops working"
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
