oops! mdf split
lemeek36
Member - Posts: 15
Posted: August 20, 2003 at 2:26 AM / IP Logged
i was putting my enclosure together yesterday and the mdf split. will i hav to change that piece?
JamesRH
Copper - Posts: 102
Posted: August 20, 2003 at 2:28 AM / IP Logged
its a good idea, or use loads of wood glue cause when it dries it will be stonger than the MDF
lemeek36
Member - Posts: 15
Posted: August 20, 2003 at 2:40 AM / IP Logged
can i use liquid nails to seal it?
lemeek36
Member - Posts: 15
Posted: August 20, 2003 at 2:41 AM / IP Logged
can i use liquid nails to seal it? this is my first time building an enclosure.
wvsquirrel
Gold - Posts: 1,237
How big was the piece that split, and which part of the enclosure was it?
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
lemeek36
Member - Posts: 15
Posted: August 20, 2003 at 5:04 AM / IP Logged
it is 15"x11", on the bottom corner. the screw was too big.
sufferrar
Copper - Posts: 190
Posted: August 20, 2003 at 6:12 AM / IP Logged
Sometimes it helps to pre drill holes half way through to spevent splits.
"I'm So Loud It Hertz"
wvsquirrel
Gold - Posts: 1,237
Posted: August 20, 2003 at 6:21 AM / IP Logged
Here's a good link on enclosure building.
Depending on the size of the split you may be able to repair it, but I would suggest replacing it if you are able to.
Squirrel
AudioAdrenaline
Member - Posts: 33
Posted: August 20, 2003 at 1:13 PM / IP Logged
I've used liquid nails on the last 2 boxes I built, and both sealed perfectly.  If you buy the low grade stuff, it gives you a 10 minute working period and it stays flexible
lemeek36
Member - Posts: 15
Posted: August 20, 2003 at 10:36 PM / IP Logged
i did pre drill the holes and they still split. i did buy liquid nails so hopefully it works, if not i'll just try it again. thanks.
Tuesday, April 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
