keyless entry door lock problems
brandonb316
Posted: August 28, 2003 at 8:54 PM / IP Logged
This is my first keyless entry install.  All of the wires are connected, except the 2 lock/unlock wires.  I am not sure on how to wire them.  I found the WHITE/ green wire, but i  don't want to screw anything up.
Thanks brandon
auex
Platinum - Posts: 5,041
Posted: August 28, 2003 at 9:18 PM / IP Logged
What kind of car/alarm? I assume it a chrysler/dodge vehicle, do you have resistors?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
JWorm
Platinum - Posts: 2,208
Posted: August 28, 2003 at 10:04 PM / IP Logged
Also, do you have the factory alarm....cause if you do, you would probably have to use a dark GREEN/ orange wire to control the alarm/locks instead. Its kinda scary we pretty much know what kind of car you have based on the color of a wire, but you should try to give us a little more info to work with. Make/ model/ year of vehicle and make/model of keyless. Does it have built in relays or not?
auex
Posted: August 28, 2003 at 10:10 PM / IP Logged
Funny isn't it, just a single wire color and we can figure out all kinds of stuff.
