headlight instead of parking lights
babysho
Member - Posts: 45
Posted: August 28, 2003 at 10:00 PM / IP Logged
Can anyone tell me if it's ok to connect the parking light wire off the module to the headlights instead of the parking lights.
ar
auex
Platinum - Posts: 5,041
Posted: August 28, 2003 at 10:03 PM / IP Logged
If you are hooking your headlights up to the alarm's parking light output then sure, you may want to up the fuse to what the car's fuse is.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
JWorm
Platinum - Posts: 2,208
Posted: August 28, 2003 at 10:10 PM / IP Logged
Headlights are often a negative trigger, while parking lights are usually positive trigger. It will vary depending on the vehicle. Headlights also consume a lot more power than parking lights. Changing the fuse to a higher value is not the correct way to do it. You would need to use a relay to increase the current capability.
All of what I just said is rather pointless unless we know what kind of car you have so we can answer your question properly.
koolaid_67
Posted: August 29, 2003 at 9:41 AM / IP Logged
Which wire do you hook up to for park lights on a 2001 Grand Caravan
babysho
Member - Posts: 45
Posted: August 29, 2003 at 5:09 PM / IP Logged
I have a 99 ford taurus se. I just want to make sure it's safe. I don't want to burn the headlights electrical system. I notice that some car makers like dodge intrepid uses the front headlight on their factory alarms so I was curious if it was also safe to do.
ar
elrayodesinaloa
Copper - Posts: 120
Posted: August 29, 2003 at 6:49 PM / IP Logged
According to mecp is not recommended because of the current draw and life of the bulbs
babysho
Member - Posts: 45
Posted: August 29, 2003 at 7:18 PM / IP Logged
you mean it could cause a fire?
ar
babysho
Member - Posts: 45
Posted: August 29, 2003 at 7:29 PM / IP Logged
HI try the light GREEN / WHITE(-) at the headlight switch harness left column make sure when you find the wire use a multimeter and test.
ar
elrayodesinaloa
Copper - Posts: 120
Posted: August 30, 2003 at 2:06 PM / IP Logged
Well a fire can be avoided by adding a fuse to the relay, that way if something happens the fuse will fry and not your car. That is, if you decide to do the headlight instead of the parking light just keep in mind that if the alarm goes off for a long period of time your battery will run dead because of the current draw.
babysho
Member - Posts: 45
Posted: August 30, 2003 at 8:04 PM / IP Logged
Oh, I understand now what your tring to say I didn't realize that the battery would run dead from the current draw. Well I change my mind I'll leave it the way it is thanks for your help!!
ar
