isobaric or not
Ketel22
Silver - Posts: 976
Posted: September 04, 2003 at 8:34 PM / IP Logged
can anybody vouch for the effectiveness or the usefull ness of isobaric set or vs just 4 just in seperate boxes?
by the way i will have infinity kappa perfect 12.1d
Quad L Handyman services
auex
Platinum - Posts: 5,041
Posted: September 04, 2003 at 9:00 PM / IP Logged
Personally I wouldn't use an isobaric enclosure. Sure they require less space but they also use twice as much power to achieve the same amount of sound. If you didn't see the page on sealed sub enclosures then here is the link
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Maxst
Silver - Posts: 866
Posted: September 04, 2003 at 9:03 PM / IP Logged
also they are very complicated and arent the best set up.
I need quality equipment, feel free to donate.
Ketel22
Silver - Posts: 976
Posted: September 04, 2003 at 9:08 PM / IP Logged
what is the best recommened setup using 4 subs?
Maxst
Silver - Posts: 866
Posted: September 04, 2003 at 9:13 PM / IP Logged
Sealed..
i would have two subs on one side of the trunk.. and the other two on the other side..in like a V. placing amp(s) in the center between the subs.
auex
Posted: September 04, 2003 at 9:38 PM / IP Logged
What is the vehicle?
Ketel22
Silver - Posts: 976
Posted: September 04, 2003 at 10:39 PM / IP Logged
i would put them in a v except this is my mothers 2002 altima everyday car
DYohn
Platinum - Posts: 10,741
Posted: September 05, 2003 at 7:24 AM / IP Logged
You're going to put 4 Perfect 12's in your mother's car?  You better ask her first if she ever intends to put groceries in the trunk.
Seriously, and I'm not trying to slam you, but wait until you get your own car.  Then you can do whatever you can afford...
Ketel22
Silver - Posts: 976
Posted: September 05, 2003 at 1:17 PM / IP Logged
ialready have my own caar but im using the subs in hers cuz she offered to buy them
DYohn
Posted: September 05, 2003 at 1:45 PM / IP Logged
Unless you really like the sound of an isobaric enclosure, don't do it.  Use a standard sealed enclosure and it will sound better and allow the Perfect's to oeprate closer to their peak efficiency.  An isobaric enclosure will allow you to build a smaller enclosure, but you will lose 9 db of spl over what two 12's in sealed anclosures will give you.  Plus, isobaric enclosures are harder to build and get them "right."  I'd build sealed enclosures.
