window roll up
brianh
Silver - Posts: 518
Posted: September 20, 2003 at 6:50 PM / IP Logged
Has anyone out there done this on a 1999 Eddie Bower Ford Explorer ? The Commando unit that I have says that there is two diffrent systems. An A and a B system. I belive I can just feed the module 12 volts,ground,and input from alarm and then cut and splice the window wires. If there is anything out of the ordinary about this please let me know. Thanks in advance.
Brian
owner/installer
Sight & Sound Car Stereo
"all electronic equipment runs off of smoke, once you let it out, it stops working"
Platinum - Posts: 12,488
Posted: September 21, 2003 at 9:43 AM / IP Logged
Hey Brian , the system is a Type A . What you have described is all you have to do. Nothing special about the Ford's wiring.
brianh
Silver - Posts: 518
Posted: September 21, 2003 at 2:36 PM / IP Logged
Thanks for the quick answer Jeff. I fiqured thats all that I had to do but I wanted to double check. I should have to go into the driver door to get that window wire but the rest should be in the kick right? Thanks for your help.
Brian
owner/installer
Posted: September 22, 2003 at 4:22 PM / IP Logged
Yup.
