remote start...1st gear only
bigt_45
Copper - Posts: 48
Posted: September 25, 2003 at 7:15 PM / IP Logged
i put a designtech remote start on my dads 1996 gmc suburban.  everything works the way it should, but the truck wont shift out of first gear.  i am stumped!!!
Platinum - Posts: 12,488
Posted: September 25, 2003 at 7:22 PM / IP Logged
You forgot to power up your 2nd IGN wire ( WHITE ). You also might have the infamous PINK/WHITE wire as well that you will have to power up. You will have to use a relay to power up these wires unless the RS has a designated 2nd IGN output that is (+)
NowYaKnow
Gold - Posts: 1,217
Posted: September 26, 2003 at 5:10 AM / IP Logged
<<designtech>>
You'll want to use the blue ignition output (+) from the remote start for your ignition 1 (pink in car) and the green ignition 2 (+) output from the remote start for your ignition 2 (white in car). Hopefully that works out for you.
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
