95 Cavalier 2.2L
rdm1
Posted: September 15, 2003 at 10:20 AM / IP Logged
Where is the PCM on a 95' Cavalier 2.2L?
StealthEs
Copper - Posts: 326
Posted: September 23, 2003 at 7:47 PM / IP Logged
Not 100% sure but I dont think your car has one. What are you looking for in the PCM?
Cris
rdm1
Posted: October 03, 2003 at 12:26 PM / IP Logged
Is there a tach wire anywheres .... I can't seem to find one
Platinum - Posts: 12,488
Posted: October 03, 2003 at 7:30 PM / IP Logged
TACHOMETER|*1                  |   |engine harness *1
The engine harness is found next to the battery, below the radiator hose, just above the transaxle. Use white or orange on the 2.2L motor, and PURPLE / white on the 2.3L motor.
rdm1
Posted: October 05, 2003 at 12:54 PM / IP Logged
Are you sure.. neither of those are making my needle tach move
rdm1
Posted: October 08, 2003 at 9:21 AM / IP Logged
The white wire on the engine harnish doesn't make my tach move... is there another wire i can use
95' 2.2L Cavalier
defective
Silver - Posts: 642
Posted: November 15, 2003 at 8:40 AM / IP Logged
there may be a purple wire with a white stipe at the ignition module. try getting tach at the white and PURPLE / white at the ignition module on driver rear of engine compartment. you can also try getting tach at the ECM at passenger front of engine bay. these are for the 2.4.  if it's a 2.2 the white wire at the PCM is a 2 cyl signal, theres also a dark blue/white at the pcm, this is a 12 cyl signal. If your trying to hook up an aftermarket tachometer you will have to use a module to convert tach signal to either 4,6,or 8 cyl signal.
goodluck
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
