88-92 mazda mx-6 remote starter
Scott105
Member - Posts: 29
Posted: July 15, 2002 at 10:42 PM / IP Logged
i would like to put a remote starter on this vehicle but it is a stick(5-speed). how would i go about wiring it to start the vehicle being that u usually have to sink the clutch to start the vehicle...
Platinum - Posts: 12,488
Posted: July 16, 2002 at 1:13 AM / IP Logged
The clutch has two wires attached to the pedal. One is for the clutch activation and the other is for cruise disengage relay. All you have to do is find the correct wire ( I'm not sure on these vehicles ) and hook up a 12 volt or ground signal to it when you activate the remote start option. You can use the STARTER output if the clutch requires a 12 volt + input or if it requires a (-) input you can use the Ground out when running wire to activate the clutch.
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
