question regarding 555u immobiliser
phatmitz
Posted: October 07, 2003 at 12:21 AM / IP Logged
Does anyone know if you need to have the factory key with the chip in order to start vehicle after installing the 555u?
Thanks, Corey
NowYaKnow
Gold - Posts: 1,217
Posted: October 07, 2003 at 5:12 AM / IP Logged
Yes you still need the normal key to start the vehicle after installing, a 555u doesn't change that. Although if you hooked up the 555u to ignition instead of the ground out off the remote start you might be able to use a non-chipped key because it would be getting the signal off of the 555u..Not positive on that I wouldn't mess with it though..Good luck
phatmitz
Posted: October 10, 2003 at 4:20 AM / IP Logged
Well I did find out that you do need the chipped key to start the vehicle.  I experimented by having a non chipped key cut and it wouldnt start the vehicle
NowYaKnow
Gold - Posts: 1,217
Posted: October 10, 2003 at 4:37 AM / IP Logged
"I experimented by having a non chipped key cut and it wouldnt start the vehicle"
Did you have the bypass active when you tried this?
defective
Silver - Posts: 642
Posted: October 10, 2003 at 11:06 AM / IP Logged
yes that ignition ground trick works.... but will cause issues with the insurance company if the vehicle is investigated...grin.  Kind of like leaving the emergency brake wire off when installing a dash screen, but i think we all 'forget' to connect that one.
Chris Luongo
Platinum - Posts: 3,746
Posted: October 10, 2003 at 5:11 PM / IP Logged
Don't forget, you can remote-start your car first, then still be able to use your non-chipped key to drive away.
daniel2002p
Silver - Posts: 524
Posted: October 10, 2003 at 7:57 PM / IP Logged
I would try using the 555L on that car.  Sometimes it worked for me and didn't need the key.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
