Check engine light. Why?
thym8scallmet
Member - Posts: 48
Posted: October 10, 2003 at 1:59 AM / IP Logged
Can any body tell me why after installing a remot start, the Check engine light might come on??  I have checked everything that I did and there seems to be no problem on my end.
Thanks    T
Drive it like you rented it!!!!!
Platinum - Posts: 12,488
Posted: October 10, 2003 at 5:20 AM / IP Logged
Most of the time it's because you did not power up an ignition or an accessory wire that needs to be powered. What year, make & model vehicle is this your installing into ?
thym8scallmet
Member - Posts: 48
Posted: October 10, 2003 at 2:07 PM / IP Logged
this is on a 96 chevy blazer.  The wiring diagram from this site show that it is supposed to have 3 ingition wires, but the rs only comes with 2 hook ups.  Is This the Problem....If so how do I fix it??
daniel2002p
Silver - Posts: 524
Posted: October 10, 2003 at 8:00 PM / IP Logged
Add another relay for you third ignition.  Not a biggie at all.  That should take car of the light
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
thym8scallmet
Member - Posts: 48
Posted: October 10, 2003 at 9:07 PM / IP Logged
hmmm     sounds easy...    how do i do that????
daniel2002p
Silver - Posts: 524
Posted: October 11, 2003 at 6:37 AM / IP Logged
Here is what I would do.  I would buy a relay and hook it up as follows.
Red Wire  -   Ignition output from brain
Black wire  -  Ground (VERY GOOD GROUND)
Yellow wire  -  12volt constant supply (Ignition harness)
Brown wire  -  Hook up to third ignition wire
Orange wire - Do not use
This is with a Directed relay and recomend you use these since they can handle a lot of current.  Let me know if you have any more q's!
    1.8L VVT-i I-4
Jimbob
Member - Posts: 49
Posted: October 11, 2003 at 3:01 PM / IP Logged
Pin 30 goes to the 3rd igntition wire you need to power up
Pin 87 goes to fused 12v+ power source
Pin 86 goes to an Ignition  wire
Pin 85 goes to a (-)out when running wire from the RS.
tjdurham
Copper - Posts: 180
Posted: October 11, 2003 at 11:28 PM / IP Logged
you dont need to hook up 3 ign wires you just have to hook uo
PINK_ IGN1
WHITE IGN2
ORANGE ACC
be sure white is hooked up as true ignition not acc
tj
thym8scallmet
Member - Posts: 48
Posted: October 12, 2003 at 5:34 PM / IP Logged
So what you are saying is that the brown wire does not even need to be attached
Sound World
Member - Posts: 20
Posted: October 12, 2003 at 11:02 PM / IP Logged
Brown is just an ACC it powers the radio
