nissan pathfinder tach search
Alpine Guy
Platinum - Posts: 2,478
Posted: October 26, 2003 at 8:38 PM / IP Logged
i have worke on a few nissan pathfinders, all 1990-1995, with the same motors, and i have tryed everything to get them to start on cold days, they just don't.  I connected the tech wire to the tac, nothing, tryed revving the engine 200 rpm higher to set the tac so it cranks more, but still not enough, i tryed the fuel injectors, and tryed the revving the engine higher to set the tac senceing, but still no start when its cold, all the pathfinders just crank and fire once or twice, they do the blub blub die kinda deal, , , , any idea's??
Platinum - Posts: 12,488
Posted: October 26, 2003 at 9:13 PM / IP Logged
Did you have the cold start starter wired in to these trucks ? You have to have both start wires hooked up in order for the vehicle to start properly in colder temps. They are usually BLACK / YELLOW and the best way to do this is to add another relay like this.
Alpine Guy
Posted: October 27, 2003 at 8:09 AM / IP Logged
huh, i did not know that there is 2 start functions on some vehicles, wow velocity motors, your turning out to be the greatest help on this board! i'll try the relays, hope they work.
Thank you.
Posted: October 27, 2003 at 8:39 AM / IP Logged
No problemo. Please post your results and let us know how you made out.
Alpine Guy
Posted: October 28, 2003 at 8:18 PM / IP Logged
whell, i put the relay on my truck last night, and it seems to have worked, but it hasn't been below freezing today, , tomorrow morning it will be about -3 degrees celcius, so i'll give it a test.
NowYaKnow
Gold - Posts: 1,217
Posted: October 28, 2003 at 9:27 PM / IP Logged
Hmm at least you got your troubleshooting down for not starting when cold nissan pathfinder tach search -- posted image. Definately post an update for us but I can almost guarantee that's your problem..I usually just tie both wires together you can do that if you don't have any relays handy it won't hurt anything. Couse the relay method is considered the "proper" way of doing things..You will run into the 2 starter wires on Nissans often and a couple other random cars as well so keep and eye out and check the info for them first they usually list it. Good luck,
Mike
Alpine Guy
Posted: November 01, 2003 at 9:10 PM / IP Logged
Whell, the relay worked on my pathfinder, but not on one of my best customers pathfinder, it dosn't start on first crank, but does on 2nd crank.
What would it be?? its a 1995 Nissan Pathfinder, Automatic, V6 3.0L, and the starter is an Autostart AS-1230.
He just got a new fuel pump, and now he's getting new plugs since they haven't been chaged in 3 years.  But if new plugs dosn't solve it, what could it possibly be??  the starter only cranks for like 2 seconds, it dosn't even let the engine fire.  I did the tac search about 20 times, i even tryed setting it 500rpm higher, still no start  on first crank.
Help!
