alpine SEC-150R
tommy1403
Member - Posts: 12
Posted: July 19, 2002 at 9:53 AM / IP Logged
Does anyone have the wiring diagrams for this alarm that show how to connect vacuum locks?  I have the diagrams that came with it, but it has no lock diagrams.  thanks
Platinum - Posts: 12,488
Posted: July 19, 2002 at 10:51 AM / IP Logged
https://www.the12volt.com/doorlocks/page3.asp#vac
tommy1403
Member - Posts: 12
Posted: July 19, 2002 at 11:15 AM / IP Logged
i did that, it didn't work.  i was wondering if anyone had the alpine wiring diagram.  http://friendlyautobody.com/locks.doc shows a different version (3rd diagram).  would that work?  green is (-) lock, blue is (-) unlock.
tommy1403
Member - Posts: 12
Posted: July 19, 2002 at 11:16 AM / IP Logged
this is for a 1985 mercedes 500sec, by the way.
Posted: July 19, 2002 at 11:35 AM / IP Logged
You may need to set the door lock pulse for 3 seconds or longer instead of a 1 second pulsed. What is the factory settingon the 150R ??
tommy1403
Member - Posts: 12
Posted: July 19, 2002 at 11:39 AM / IP Logged
the factory setting is 1 sec, but i changed it to 3sec.  the unit puts out the correct 3 sec pulses, but i'm not getting anything out of the relay (into the pump).
Posted: July 19, 2002 at 11:50 AM / IP Logged
Just curious.... does the Alpine system have built in relays for this type of system ?? I've worked with Alpine for sometime now and they have internal relays for this type of door lock system. I've not had the opportunity to work with the 150R yet so that is why I'm asking.
tommy1403
Member - Posts: 12
Posted: July 19, 2002 at 11:58 AM / IP Logged
i have no idea, that's why i was asking.
tommy1403
Member - Posts: 12
Posted: July 19, 2002 at 12:24 PM / IP Logged
do you know if I can contact alpine tech support somehow and get a diagram?  the manual for the SEC-8028 mentions something about Alpine FastFax, but it gives no phone number.  I've tried almost everything.
Posted: July 19, 2002 at 12:27 PM / IP Logged
Can you scan the wiring diagram of the 150R that you got from the alarm installation sheet ? Please email it to me at velocity@valleycable.com or fax it to me at 1-204-822-1266
