Which is a better rellay BOSCH or SIEMENS
Dan M C
Copper - Posts: 220
Posted: July 20, 2002 at 7:51 AM / IP Logged
I was just wondering,cause i came across this deal on some SIEMENS rellays,now since most people use BOSCH should i compromise or not to worry,what do you guys think ?
Thank you !Which is a better rellay BOSCH or SIEMENS - Last Post -- posted image.
Dan M C
sparkyssb
Copper - Posts: 205
Posted: July 20, 2002 at 8:32 AM / IP Logged
Do the SIEMENS come with a diode built in? (polarity)
Dan M C
Copper - Posts: 220
Posted: July 20, 2002 at 9:11 AM / IP Logged
Virtualy the same as the BOSCH,just concerned with reliability,the shop that sells them claims that they are used same as the BOSCH,in stuff like alarms,etc.
Dan M C
Moderator - Posts: 12,488
Posted: July 20, 2002 at 9:24 AM / IP Logged
I've used alot of different relays in the past ( Potter Brummfield, Bosch, Siemens, cheap no name generic brand ) and they all work the same. In the end I would rather pay 75 cents for a relay than $ 5.00 for a brand name one that does the same thing. I have not had a single one of those cheaper relays come back or fail in any of the installs that i've done.
Dan M C
Copper - Posts: 220
Posted: July 20, 2002 at 10:02 AM / IP Logged
Which is a better rellay BOSCH or SIEMENS - Last Post -- posted image.Thanks Jeff !Which is a better rellay BOSCH or SIEMENS - Last Post -- posted image.
Dan M C
Pickle
Member - Posts: 8
Posted: July 21, 2002 at 10:16 PM / IP Logged
To continue this a bit farther...does anyone have any part numbers for a particular brand's relays?  I get strange looks at the generic auto parts stores when I ask for a SPDT relay, and the electronics shops tend to have very expensive, large industrial stuff (too big for motorcycle apps), and/or they've only got 4PDT relays, high pull-in voltage ratings, etc...
Anyone have specifics?  (Cheaper and smaller, the better, of course...)
Thanks,
Chris
Posted: July 21, 2002 at 10:39 PM / IP Logged
One member suggested going to an automtive wrecker for cheaper relays. He got quite a few for a couple of dollars and you would have your choice of size and amperage as well.
Pickle
Member - Posts: 8
Posted: July 21, 2002 at 10:51 PM / IP Logged
Ahh...thanks!
That makes sense...wide selection & cheap prices...can't beat that!
hot_shot_guy123
Copper - Posts: 114
Posted: July 23, 2002 at 9:54 PM / IP Logged
I like the Siemens relays.  I used a few cheap ones and they failed, I have never had a problem with these ones though.
"Light travels faster then sound, that's why some people seem bright until you hear them speak."
hot_shot_guy123
Big Dog
Gold - Posts: 1,265
Posted: July 24, 2002 at 2:19 PM / IP Logged
Hey   Pickle,
Cheap relays can sometimes be good.  I say sometimes because I wouldn't trust a cheapie for ignition or starter kill but for trunk release I'd slap the sucker in inside of a wink. Which is a better rellay BOSCH or SIEMENS - Last Post -- posted image. Which is a better rellay BOSCH or SIEMENS - Last Post -- posted image.
Prepare your future. It wasn't the lack of stones that killed the stone age.
Sunday, May 19, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
