Chrysler neon keyless entry
stirfie
Posted: November 11, 2003 at 5:10 AM / IP Logged
I have a 97' chrysler neon, and I am trying to install an immobiliser with remote keyless entry. I know I will have to use relays, as immobiliser has a negative output, but can anybody help me with the actual connections.
Any help would appreciated
desh187
Copper - Posts: 310
Posted: November 12, 2003 at 11:25 PM / IP Logged
97 neon
connect 12 volts to pink/black ignition harness
ignition to dark blue
starter wire is yellow use a relay.
power lock-ORANGE / violet driver kick panel
power unlock-pink/violet (5 wire reversal rest at gnd)
park lamps-BLACK / YELLOW-at light switch.
silvercivicsir
Copper - Posts: 416
Posted: November 22, 2003 at 2:57 AM / IP Logged
Sorry I'm also trying to do do keyless entery on a 96 neon same wire colors. looking at the diagram for "aftermarket relays" how do i hook up the power lock/unlock wires ? would they go to Pin 30 on the relays ?
NowYaKnow
Gold - Posts: 1,217
Posted: November 22, 2003 at 7:58 AM / IP Logged
You would need 2 relays and hook them up like so:
Relay 1
85: To (-) lock output on module
86: To constant 12v fused
87: To constant 12v fused (Can tie 86 into 87)
87a: To switch side of ORANGE / violet lock wire
30: To motor side of ORANGE / violet lock wire
Relay 2
85: To (-) unlock output on module
87a: To switch side of pink/violet lock wire
30: To motor side of pink/violet lock wire
Once you find the wires you need you have to cut them. You see above after you cut them one side goes to pin 87a and the other side goes to pin 30. After cutting the wire test to see which side is the switch side and which side is the motor side. Put your meter or test light on one side and hit the lock or unlock switch depending on what you are doing. If it gets 12volts when you hit the switch, that is your switch side. The other side that doesn't get any voltage when you hit the switch is your motor side. Hope that clears it up..Good luck,
Mike
