who loves t-taps
dan768
Copper - Posts: 49
Posted: July 21, 2002 at 9:55 PM / IP Logged
Hello I have been using t-taps forever,I've done thousnds of installs with them and I have never had any problem with them.Does anyone have any comments?
dan
Remember (there are no hard cars,some just take longer to install on then others)
Platinum - Posts: 12,488
Posted: July 21, 2002 at 10:06 PM / IP Logged
****** THIS IS MY OPINION NOT THE GOSPEL TRUTH **************
Now......... got that off my shoulders, I don't like using T-taps because there's an issue about longevity and I have un-installed hundreds of systems with them in there and about 1/4 of then, the T-tap loosened to the point where the cover was open exposing the wire and the blade connector. I know not everyone has the opportunity to un-install another installers installation, but I have and that is why I know I don't like them.
My 3 c's who loves t-taps -- posted image.
dan768
Copper - Posts: 49
Posted: July 21, 2002 at 10:13 PM / IP Logged
That is true in the hand of a novice installer there can be problems,but I have found that a lot of the alarms I de-install some times have the wrong male spade, I only use the 3M t-tap and 3M male spade.I like them because they snap in place so firmly I need pliers to pull them apart.So in essence I think the big problem with them is using incorrect male spades.
dan
omegamotorsprts
Member - Posts: 18
Posted: July 21, 2002 at 10:31 PM / IP Logged
at Best Buy we can not under any circumstance use them, so I haven't missed them much, and I've found a pay a good amount of attention to it when it's not so simple, not saying they aren't useful, I just don't personally use them.
mobiletoys2002
Gold - Posts: 1,050
Posted: July 22, 2002 at 7:09 AM / IP Logged
To be honest with you in my tool box i dont have not one t tap i dont use them ever. The closest thing to a t tap i have is  crimp on ring terminals and those i rarely use only for a ground here and there. The only shops i see use t taps are places that don't care if installs come back there more interested in volume sales then quality work they dont want to take extra time to do it right the first time. What i never really understood is these shops think  soldering takes to long, well with a good iron and some practice it's actually verry easy. And with all the time the shop has to spend on customers coming back with intermident connections and stuff you could have done it right the first time.
HEY DAN768, WHAT DO YOU USE ON HIGH CURRENT APPLICATIONS LIKE STARTER WIRES, IGNITION WIRES, AND MAIN POWER WIRES. ?????
dan768
Copper - Posts: 49
Posted: July 22, 2002 at 8:29 PM / IP Logged
Hello, well I do t-tap(gasp!) 12g. ignition wires but at least I strip back the insulation before I tap the 10g. ones.Also a lot of the time I have other alternate wires (smaller gauge) I can grab, instead of going to the ignition harness.I do know how to solder(thats all I was allowed to do at lojack) but since I pre-load alarms they must be somewhat de-installable.
dan
Xtra
Posted: July 26, 2002 at 5:21 AM / IP Logged
I solder and tape every connection, sometimes use a ring terminal for ground depending on the vehicle.
I have very few come backs due to installation problems but I do have many refits of alarms installed using crimps and scotchlocks.
I have been installing for about 12 years and here using crimp connectors, scothlocks,ttaps is pretty much frowned apon.
Systems and installations in Australia have to meet a certain standard to be Govt and Insurance approved such and all black wiring, dual point immobilisation, hidden wiring and concelled plug/sockets etc.
Dan
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
