Alarm Wiring, 2001 Honda Prelude
Welcome Guest :)
sazaks
Member -
Posted: July 22, 2002 at 9:08 AM / IP Logged
Would anyone have the wiring diagram for a 2001 Honda Prelude.
Marc
mobiletoys2002
Gold -
Posted: July 22, 2002 at 10:32 AM / IP Logged
dan768
Copper -
Posted: July 26, 2002 at 7:51 AM / IP Logged
Heres the alarm wiring.
Year(s): 97-01 | Make(s): Honda | Model(s): Prelude | |
12 Volt (+) | 12ga. White at Brown 2 pin connector left of steering column |
Ignition 1 | 12ga. BLACK / YELLOW at ignition harness |
Ignition 2 | |
Ignition 3 | |
Accessory 1 | 12ga. Yellow at ignition harness |
Accessory 2 | |
Starter | 14ga. BLACK/ White at starter relay located left of steering next to Brown 2 pin connector |
Horn | 18ga. Lt. GREEN/ Blue (-) at Gray 3 pin connector left of steering column |
Tachometer | 18ga. Blue at 2 pin connector on top of right shock tower in engine compartment |
Lights (+) | 18ga. RED / Black at back of dimmer switch directly below left dash vent (vent is easily removed by lifting up on bottom edge and pulling back) |
Lights (-) | |
Brake Lights | 18ga. WHITE/ Black (+) or GREEN / WHITE at brake pedal switch |
Door 1 | 18ga. Green (-) (driver door) below left dash vent (remove vent by lifting up on bottom edge and pulling back) |
Door 2 | 18ga. GREEN/ Orange (-) (passenger door) at same |
Door 3 | |
Door 4 | |
Interior Lights | 18ga. WHITE/ Black (-) at steering column in harness leading to light ring around key cylinder |
Trunk/Hatch | 18ga. Orange (-) next to door triggers |
Hood Pin | |
Trunk Release | |
Lock (switch) | 18ga. BLACK/ White (-) at Gray 2 pin connector wrapped in Blue tape left of steering column |
Unlock (switch) | 18ga. Blue/Orange (-) at same (for later models if connector is not at driver’s side go to passenger’s kick panel and find wires there at MPX module) |
Driver Unlock | |
Arm (key) | 20ga. RED / White (-) at factory alarm harness located above foot pedals (should also lock doors) |
Disarm (key) | 20ga. GREEN/ Orange (-) at same (should also unlock doors) |
Arm Input | 16ga. WHITE/ Red (M) under left side of dash in White connector heavily taped to large harness |
Disarm Input 1 | 16ga. Lt. GREEN/ Red (M) at bottom of fuse box behind driver’s kick panel in 3 pin connector |
Disarm Input 2 | 16ga. Lt. GREEN/ Red (M) under left side of dash in White connector |
dan
Remember (there are no hard cars,some just take longer to install on then others)
sazaks
Member -
Posted: August 01, 2002 at 8:29 AM / IP Logged
Dan,
Would you have anything for the Stereo? I'll be changing the HU tonight.
Sunday, August 9, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
