95 maxima, alarm/Remote starter
MaxV6
Member - Posts: 22
Posted: January 11, 2004 at 12:01 AM / IP Logged
Loveforyou wrote:
Do i need to bypass something on this car? I want stand alone with combo remote starter? I just want the factory alarm deactivate how? What are the trick to install on this car? someone already have experience with this car? I'm just first time install alarm on my car. I got all my diagram I try installed past weekend didn't work? car won't start but the relay clicking!! I dont know what i'm doing wrong ? thank you everyone for helping .
Is it a manual gear box? If it is, try stepping on the clutch while remote starting. If so, then you need to bypass the clutch in RS mode.
Factory alarm deactivate (disarm) should be a single pulse to the unlock wire. To test if the factory alarm is interfering, unlock using the door switch and remote start it.
If you needed a transponder bypass the starter would crank but the engine  won't start.
Loveforyou
Member - Posts: 39
Posted: January 11, 2004 at 9:11 AM / IP Logged
NO is not manual . Soo i dont really need to bypass somethings right?
Loveforyou
Member - Posts: 39
Posted: January 11, 2004 at 6:41 PM / IP Logged
OK today i hook it up the remote starter work fine but first attempt it crank but won't start. 2 time started but sometime won't start ,3 time usually started. what i'm doing wrong here please help me to get it right start at first time.  then i try hook up the tach wire doing problem. Where is the location Door trigger , Door lock, Door unlock? i can't find those wires i wan't hook it up for keyless entry. thank you
Loveforyou
Member - Posts: 39
Posted: January 11, 2004 at 6:52 PM / IP Logged
I know them wires are located at the Switch but i dont want run the wires thru the firewall to get in the power door switch. please help me I want keyless entry to work. seen like i can't find those from driver kick panel. help me please anyone!!!
draasch
Gold - Posts: 2,172
Posted: January 12, 2004 at 3:09 PM / IP Logged
Make:   Nissan
Model: Maxima
Year:    1995
This Database Was Last Updated On:    6/9/2003
Index #: 1890
Alarm
Constant 12 volts WHITE/ PURPLE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ RED IGNITION SWITCH HARNESS
Starter BLACK/ WHITE IGNITION SWITCH HARNESS
Dome Light RED / WHITE (-) JUNCTION BOX BEHIND CONSOLE
Trunk Pin Switch PURPLE / YELLOW (-) AT SWITCH OR LIGHT
Parking Lamp RED / GREEN (+) HEADLIGHT SWITCH OR FUSE BOX (FUSE 5)
Power Lock LIGHT GREEN/ RED AT SWITCH IN #214
Power Unlock GREEN/ YELLOW DRIVER DOOR *
* Warning!! This Car Uses A Data Link System For Door Locks. Each Switch Is A Local Control Unit. Wire Colors Given Are At Each Switch In Each Door. Negative Pulse On L GREEN/ RED Wire Will Lock All Doors. Double Negative Pulse On GREEN/ YELLOW Wire Will Unlock All Doors. #214- See Nissan Door Lock Diagram.
Remote Start
Tach Signal WHITE/ GREEN AT ENGINE CONTROL MODULE *
Ignition #2 RED / YELLOW IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory WHITE/ BLUE IGNITION SWITCH HARNESS
Neutral Safety GREEN/ ORANGE SWITCH ON DRIVER FRONT OF TRANSAXLE
Brake Light RED / GREEN (+) SWITCH ON BRAKE PEDAL BRACKET
Reverse Light GREEN / WHITE (+) SWITCH ON DRIVER FRONT OF TRANSAXLE
Rear Window Defrost N/A
* Engine Control Module Located Behind Center Console.
http://wiringinstructions.com/214.htm
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Loveforyou
Member - Posts: 39
Posted: January 14, 2004 at 11:24 PM / IP Logged
I'm installed combo remote starter on my 95 maxima I have problem with starting the car, it crank but somtime work start usually the 3rd time started. so I have hook up the tach wire to ECM but no help anyone figure out what i'm doing wrong here thank. other thing is I want hook up the keyless entry but i am not sure where i can find the right wires in my car. someone know where the they locate? help please appreciate.
here what i have done hook up
       Violet =positive door input + ?
       Orange (-) armed output (500ma) ?
       Blue/White (-) passenger unlock
       Green =Negative door input
       Blue&White= Passenger unlock output(-) 500ma
        where is the factory disarm wire locate in my 95 maxima? Those wires i left out. any one know where i should hook up to? thank you
boomer_106
Silver - Posts: 710
Posted: January 14, 2004 at 11:30 PM / IP Logged
Here ya go
1995-97 Nissan Maxima Alarm Information
Heres another one since it tells you where the factory disarm is.
Nissan
Maxima
1995-1995
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
BLACK/ WHITE
IGNITION SWITCH HARNESS **
Ignition #1:
BLACK/ RED
Ignition #2:
RED / YELLOW
Ignition #3:
N/A
Accessory:
WHITE/ BLUE
Brake Light:
RED / GREEN
Tach Signal:
WHITE/ GREEN
Parking Lights:
RED / GREEN (+)
Headlights:
LT GRN/BLACK (DRV) AND
GRN/YELL (PASS) @ SW.-HIGH BEAMS (+)
OEM Alarm Disarm:
GREEN/ YELLOW (-)
EITHER FRT DOOR AT LOCAL CONTROL UNIT
OEM Alarm Arm:
LIGHT GREEN/ RED (-)
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
* Engine Control Module Located Behind Center Console. ** This Vehicle Is Equipped With Two Start Wires. Both Must Be Connected to Remotes Starter Wire In Order For Vehicle To Start When Engine Is Cold; See Note #235 - Nissan Starter Wires Diagram For Complete Information.
Nissan
Maxima
1995-1995
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
WHITE/ PURPLE
Starter Kill:
BLACK/ WHITE
Ignition +12 Volts:
BLACK/ RED
Dome Lights/Superv:
RED / WHITE
OEM Horn:
GREEN / WHITE
(-) STEERING COLUMN HARNESS
Power Lock:
LIGHT GREEN/ RED
AT LOCAL CONTROL UNIT (DR. SWITCH)***
Power Unlock:
GREEN/ YELLOW
Trunk Release:
PURPLE / WHITE (-)
KEYLESS MOD.IN PASS.TRUNK
Alarm Input Wire:
RED / WHITE
Notes:
*** See Note #231 - Double Pulse Door Lock Diagram, or program module for double pulse door locks.
Loveforyou
Member - Posts: 39
Posted: January 14, 2004 at 11:47 PM / IP Logged
thank you fast reply
sroth140
Silver - Posts: 513
Posted: January 15, 2004 at 10:02 AM / IP Logged
use a relay for that second starter.
Loveforyou
Member - Posts: 39
Posted: January 15, 2004 at 7:16 PM / IP Logged
What you mean? I'm not clear your answer. thank you for reply
Page of 5
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
