Door Speaker Cable and LEDs
vmail
Member - Posts: 17
Posted: December 11, 2003 at 7:55 AM / IP Logged
Hi, I would like to use my door speaker cable to create a blinking LED on the door for the alarm, the only problem is that the LEDs blow up when the radio is on.  It is very difficult to feed new wires to the door because there is no space
xetmes
Silver - Posts: 586
Posted: December 11, 2003 at 8:28 AM / IP Logged
hmmm that an odd idea... you could use a relay to disconeect from the radio when the car is off, and reconnect back to the radio when the car is on. i would not use both of the speaker wires though, just let one float and use the chassis for ground... i dont know about the whole idea though... hah
vmail
Member - Posts: 17
Posted: December 11, 2003 at 8:55 AM / IP Logged
hmmm but if I enable the alarm while the radio is still playin, it will still blow up
xetmes
Silver - Posts: 586
Posted: December 11, 2003 at 10:21 AM / IP Logged
well have it disable when the key is in acc.... why would you have the radio on and the alarm armed?
vmail
Member - Posts: 17
Posted: December 11, 2003 at 11:14 AM / IP Logged
by accident, some times when filling up with petrol, the system is still on, 2 mins later the immobiler kicks in and the LED starts flashing
crudeau
Copper - Posts: 150
Posted: December 11, 2003 at 11:43 AM / IP Logged
You can't get one 20-22 gauge wire to fit in there somehow?
vmail
Member - Posts: 17
Posted: December 11, 2003 at 12:15 PM / IP Logged
only way it to cut the wire harness, but then the wires will be unprotected
