2001 Mitsubishi Gallant ES
cdaw
Member - Posts: 22
Posted: July 27, 2002 at 8:22 PM / IP Logged
Greetins,
 I am hoping to install an Alarm/Kelyess Entry/Remote Start system to this otherwise factory car. It has no factory alarm, or keyless. However it does have some fancy tricks of it's own, that I'd rather not break. Such as the drivers door single / double pulse operation, and the auto dimming dome.
 My key does not have a visible chip, but I fear the Oversized end may contain some sort of "passlock" type thing.
If any anybody has any tips for the car, I'd be muchus thankfull.
I installed the same system successfully in my Plymoth Voyager, from the help on this site.
Platinum - Posts: 12,488
Posted: July 27, 2002 at 10:07 PM / IP Logged
Mitsubishi
Galant
1999-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK / YELLOW
IGNITION SWITCH HARNESS *
Ignition  #1:
BLACK/ WHITE
Ignition #2:
BLUE/RED
Ignition  #3:
N/A
Accessory:
BLUE/BLACK
Brake  Light:
GREEN/ 2 SILVER BARS
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
WHITE
IN CONN. NEXT TO FUSE BOX UNDER HOOD
Parking Lights:
GREEN / WHITE (+)
BY FUSE BLOCK DRIVER'S SIDE DASH
Headlights:
OEM Alarm  Disarm:
BROWN / WHITE (-)
IN LOWER KICK PANEL/HARNESS FROM TRUNK
OEM Alarm  Arm:
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * This vehicle may be equipped with a transponder immobilizer system.
Mitsubishi
Galant
1999-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
BLUE / YELLOW
Starter  Kill:
BLACK / YELLOW
Ignition  +12 Volts:
BLACK/ WHITE
Dome  Lights/Superv:
ORANGE / BLACK
DR. KICK PANEL LOW/HARNESS FROM TRUNK
OEM Horn:
GREEN / WHITE (-)
STEERING COLUMN HARNESS
Power  Lock:
VIOLET (-)
IN DR. KICK PANEL/HARNESS FROM DOOR **
Power  Unlock:
LT. GREEN/ RED (-)
Trunk  Release:
Alarm  Input Wire:
ORANGE / BLACK
Notes:
** Negative Pulse Door Lock
  • NOTE: When doing remote start on vehicles with factory alarm, must interrupt the blue/red (-) key sense wire at the steering column using the status output wire to bypass the factory starter kill
  • The door lock wires are in a black plug behind the fuse box, above a green module.
  • On the 6 cylinder models, the white tach wire can also be found at the distributor. On the 4 cylinder models, the tach wire can also be found at the ignition failure sensor on the intake manifold, the white wire is in a 4 pin plug with three BLACK/ stripe wires.
  • Horn relay in engine compartment relay box, or also found right at horn behind left side of front bumper.
cdaw
Member - Posts: 22
Posted: July 28, 2002 at 1:20 AM / IP Logged
Thanks Much!
Posted: July 28, 2002 at 8:21 AM / IP Logged
No problemo 2001 Mitsubishi Gallant ES -- posted image.
cdaw
Member - Posts: 22
Posted: July 28, 2002 at 12:32 PM / IP Logged
Well - I noticed the sticker on the window of my Galant, that says it does have the immobilizer system.
 Is this going to be a problem?, if so how do I solve it?
Thanks again.
Posted: July 28, 2002 at 12:52 PM / IP Logged
There is only one bypass module out on the market right now for the Galant and it's a KEY required bypass module., meaning that you need another key with a chip in it to bypass the anti theft unit of the car while remote starting. They go for about $ 25 - $ 40 on the internet.
cdaw
Member - Posts: 22
Posted: July 28, 2002 at 1:10 PM / IP Logged
I've tried searching for said device, with no luck. Would you happen to have a link to someplace that sells said device?
  I noticed my Ignition switch has a copper coil wrapped around it, could I not just chop off the trasponder part of the key, and sticky it to the steering colum near the coil, then I could just use normal copied keys??? anybody try that?
Posted: July 28, 2002 at 1:47 PM / IP Logged
You can do this, but it defeats the purpose of having an anti theft device in the car incase someone tries and steals the car .Not a common practice among installers to do this, but it has been done. The only problem with this is if the pellet ever falls off and you only have a copied key, your F*@ked. The car won't run or start properly without the pellet by the transponder module.
cdaw
Member - Posts: 22
Posted: July 28, 2002 at 1:54 PM / IP Logged
Well, I do have 2 real keys, I could make a new coil antenna, with the vallet key inside, and connect this to the input on the OEM reciever, all inside the steering colum.
 I'd preferfer to use the Pre -fab unit, But I still cant find a link to the device.
  I did find this though - http://www.ti.com/tiris/docs/news/news_releases/90s/rel06-01-99.shtml
Posted: July 28, 2002 at 2:03 PM / IP Logged
I will email you a way to do this. Sssshhhhh !! Installer's secret 2001 Mitsubishi Gallant ES -- posted image.
