help with Mobile Video
meh66
Copper - Posts: 266
Posted: December 17, 2003 at 10:57 AM / IP Logged
Hello,
    This will be my first moblie video install, so bear with me. I am planning on buying and DVD and separate monitor. I want to integrate this into my existing factory stereo systems. What installation do I need to make this one sucessful. Thanks for your help.
MEH66
"Car Performance and Mobile Electronic Enthusiats"
Geeque
Silver - Posts: 310
Posted: December 17, 2003 at 3:55 PM / IP Logged
Integrate sound or ? You'll need a audio/visual fm modulator to bring sound through speakers.
Gary Kline
MECP Master Technician
auex
Platinum - Posts: 5,041
Posted: December 17, 2003 at 6:27 PM / IP Logged
You will need either a FM modulator, or depending on vehicle there may be an auxillary input adapter that will supply sound through the cd changer input.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
meh66
Copper - Posts: 266
Posted: December 18, 2003 at 8:10 AM / IP Logged
Thanks....I see that it is very similar to a CD changer install.
MEH66
zeiden
Member - Posts: 31
Posted: December 20, 2003 at 5:46 AM / IP Logged
The DVD player will give you sound and video outputs.  If your monitors have headphone outputs or speakers, and you don't want the sound coming from the DVD player to play on your car speakers, then all you have to do is install the sound outputs of the DVD player to the monitor's sound inputs and your done.
In the other hand, if you want to use your car speakers as an audio source, then you will need an fm modulator
1kewlexpo
Member - Posts: 33
Posted: December 20, 2003 at 2:49 PM / IP Logged
If you use and FM modulator, make sure to install a manual switch  for it.  This will allow you more control on when you want to hear the sound out of your speakers.  Also, this will prevent any interference with your normal radio tuning.
John
meh66
Copper - Posts: 266
Posted: December 22, 2003 at 9:22 AM / IP Logged
Hello,
          Thanks for all the input. I was actually thinking about doing what 1Kewlwxpo suggested.
MEH66
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
