2003 Dodge 1500 Hemi remote start
Slcoo3
Member - Posts: 8
Posted: December 17, 2003 at 5:18 PM / IP Logged
I'm looking for the wiring diagram for the 2003 Hemi. Can any one help?
Geeque
Silver - Posts: 310
Posted: December 17, 2003 at 5:28 PM / IP Logged
2 dr or ext cab?
Gary Kline
MECP Master Technician
Slcoo3
Member - Posts: 8
Posted: December 17, 2003 at 5:35 PM / IP Logged
 The trucks a 2 dr.
Geeque
Silver - Posts: 310
Posted: December 17, 2003 at 6:15 PM / IP Logged
Dodge
Ram Pickup
2002-2004
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS
Ignition  #1:
BLUE (16 AWG)
Ignition #2:
RED
Ignition  #3:
GREEN & ORANGE (2 WIRES)
Accessory:
BLACK/ WHITE & BLUE (2 WIRES)
Brake  Light:
WHITE/ TAN
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
TAN/RED
AT IGNITION COIL
Parking Lights:
PURPLE / YELLOW
HEADLIGHT SWITCH*
Headlights:
PURPLE / YELLOW
HEADLIGHT SWITCH *
OEM Alarm  Disarm:
LT. GREEN/ ORANGE *****
HARNESS COMING IN FROM DRIVER'S DOOR
OEM Alarm  Arm:
Diesel  Glow Plug:
ORANGE / Black
Powertrain Control Module***
Clutch  Bypass Wire:
Notes:
 * This Is A Single Wire System. Parking Lights Need To See A Ground (-) Through A 330 Ohm Resistor. Headlights Need To See A Ground (-) Through A 700 Ohm Resistor. ** Diesel Vehicles - ORANGE / Black Wait to Start; Tach Wire Is Gray/Black. Both Wires Are Located In A Black Connector Center Top Of Fire Wall. There Are Two Black Connectors, The Correct One Does Not Have A White Insert. *** Tach can also be located at pin 74 behind instrument cluster.
Dodge
Ram Pickup
2002-2004
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
PINK/BLACK
Starter  Kill:
YELLOW
Ignition  +12 Volts:
BLUE (16 AWG)
Dome  Lights/Superv:
SEE NOTE ***
OEM Horn:
BLACK/ RED (-)
STEERING COLUMN HARNESS
Power  Lock:
WHITE/ GREEN
DRIVER'S KICK PANEL ****
Power  Unlock:
WHITE/ GREEN
Trunk  Release:
N/A
Alarm  Input Wire:
SEE NOTE ***
Notes:
*** Separate Triggers For Each Door. The Driver's Door Trigger Is Tan (-). The Left Rear Door Trigger Is Tan/Orange (-). Both Wires Can Be Found In The Driver's Kick Panel. The Passenger Front Door Trigger Is Tan/Red (-) And the Passenger Rear Door Trigger Is Tan / YELLOW (-). Both Of These Wires Can Be Found In The Passenger Kick Panel. Diode Isolate Each Wire For Alarm Trigger With The Bands Facing Away From The Alarm/Remote Start Module. Use Only One Trigger For Dome Light Supervision. **** Single Wire Door Lock System See Note #211. Lock Requires A Ground (-) Pulse Through A 867 Ohm Resistor. Unlock Requires A Ground (-) Pulse Through A 364 Ohm Resistor. Diode Isolate One Of The Wires. ***** Requires A Negative Pulse Through A 1.5 K-Ohm Resistor.
DesignTech  International, Inc.
Tel: (703)  866-2000 Fax: (703) 866-2001
©2002  All Rights Reserved
7955 Cameron  Brown Court
Springfield, Virginia 22153 USA
1-800-DESIGNTECH
(1-800-337-4468)
www.designtech-intl.com
DesignTech disclaims any liability or responsibility arising out of any inaccuracies of this information or use of this
information for installations or otherwise. Please verify all wiring for accuracy prior to making any connections.
Gary Kline
Geeque
Silver - Posts: 310
Posted: December 17, 2003 at 7:03 PM / IP Logged
Should be the same.
Gary Kline
auex
Platinum - Posts: 5,041
Posted: December 17, 2003 at 7:13 PM / IP Logged
Hey Geeque, as far as posting your designtech diagram's, you may want to delete the bottom portion of the diagram.
You know the part that says "©2002 All Rights Reserved"
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Geeque
Silver - Posts: 310
Posted: December 17, 2003 at 7:15 PM / IP Logged
Thanks just trying to help!
Gary Kline
Geeque
Silver - Posts: 310
Posted: December 17, 2003 at 7:16 PM / IP Logged
Let them sue me!!!!
Gary Kline
securinu
Silver - Posts: 772
Posted: December 17, 2003 at 10:50 PM / IP Logged
Also the 2004 is completely different All new colors. 02 and 03 are the same
Joe O'Byrne
Owner / Installer
Slcoo3
Member - Posts: 8
Posted: December 25, 2003 at 1:09 PM / IP Logged
Will I need an immobilizer ?
Thursday, June 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
