2003 Jeep Liberty Sport 3.7L V6
cdawg925
Posted: December 26, 2003 at 9:43 PM / IP Logged
Hello... Does anyone out there have a wiring diagram for a remote starter/stereo for a 2003 Jeep Liberty Sport 3.7L V6?  Thanks!
Teken
Gold - Posts: 1,492
Posted: December 26, 2003 at 10:24 PM / IP Logged
Jeep
Liberty
2002 - 2003
Remote Starter Wiring Colors and Notes
Function
   Vehicle Color
Location
Start:
   YELLOW
IGNITION SWITCH HARNESS *
Ignition #1:
   RED / BLUE
Ignition #2:
   BLACK/ ORANGE
Ignition #3:
   N/A
Accessory:
   BLACK/ WHITE
Brake Light:
   WHITE/ TAN
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
   TAN/RED
AT COIL # 1
Parking Lights:
   LT. GREEN/ ORANGE (-)
AT HEADLIGHT SWITCH**
Headlights:
   N/A
OEM Alarm Disarm:
   LT. GREEN/ ORANGE
DRIVER'S KICK PANEL ***
OEM Alarm Arm:
   LT. GREEN/ ORANGE
Diesel Glow Plug:
   N/A
Clutch Bypass Wire:
Notes:
   * This vehicle may be equipped with Chrysler's Smart Key Transponder Theft System Only If The Ignition Key Is Gray. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. You may also use vehicle specific bypass module part # 23568. ** Must use a relay to supply a ground pulse through a 900 Ohm resistor. *** Single Wire System. A Negative Pulse Through A 475 Ohm Resistor Will Disarm The Alarm. A Negative Pulse Through A 2 K-Ohm Resistor Will Arm The Alarm.
Jeep
Liberty
2002 - 2003
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   PINK/BLACK
Starter Kill:
   YELLOW
Ignition +12 Volts:
   RED / BLUE
Dome Lights/Superv:
   YELLOW
AT COURTESY LIGHT UNDER DASH ***
OEM Horn:
   BLACK/ RED (-)
STEERING COLUMN HARNESS
Power Lock:
   PINK/VIOLET
DRIVER'S KICK PANEL ****
Power Unlock:
   PINK/VIOLET
Trunk Release:
   ORANGE / BROWN (+)
AT BCM THAT’S INTEGRATED INTO THE FUSE PANEL
Alarm Input Wire:
   YELLOW
Notes:
*** Use For Alarm Pulse Only. For Domelight Supervision, Use Either A Tan (-) or Tan/White (-) Wire Located In A Blue Plug To The Right Of The Steering Column. These Are The Driver's And Passenger Door Pulses Respectively. **** Single Wire System. A Negative Pulse Through A 1.4 K-Ohm Resistor Will Lock The Doors. A Negative Pulse Through A 425 Ohm Resistor Will Unlock All The Doors. See Note #211 Single Wire Negative Trigger Door Locks.
