door lock wiring 1988 Merkur Scorpio
jhunter936
Posted: January 04, 2004 at 9:38 PM / IP Logged
Hi,
Anyone know the wiring codes for a 1988 Merkur Scorpio?
TIA,
Bnluis
Silver - Posts: 578
Posted: January 04, 2004 at 10:12 PM / IP Logged
   POWER LOCK|yellow              |-  |driver's kick panel *1      |
|     POWER UNLOCK|white               |-  |driver's kick panel *1
*1 Use relays - requires high current ground to operate
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
jhunter936
Posted: January 04, 2004 at 10:47 PM / IP Logged
Thanks Luis,
But what is a 'high current' ground??
Bnluis
Silver - Posts: 578
Posted: January 04, 2004 at 11:03 PM / IP Logged
door lock wiring 1988 Merkur Scorpio -- posted image.
Luis
Sound Waves
jhunter936
Posted: January 04, 2004 at 11:09 PM / IP Logged
Luis, your last reply didnt come through. Please post.
Also, I went back through 12volt and found this:
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1988-89&make=Merkur&model=Scorpio&ID=18440&type=Alarm
This one says unlock is reverse polarity. How is that wired into an alarm?
Bnluis
Silver - Posts: 578
Posted: January 04, 2004 at 11:31 PM / IP Logged
go to the door lock section and see how to wire relays to give you a negative trigger Every where I look I see car as having negative locks that require a strong ground
Merkur
   Scorpio
1988-1989
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED
IGNITION SWITCH HARNESS
Starter  Kill:
BLACK/ BLUE
Ignition  +12 Volts:
BLACK / YELLOW
Dome  Lights/Superv:
BROWN / WHITE
(-) AT FUSE BOX OR COURTESY LIGHT
OEM Horn:
RED
(-) STEERING COLUMN HARNESS
Power  Lock:
YELLOW
DRIVER'S KICK PANEL *
Power  Unlock:
WHITE
Trunk  Release:
RED / GREEN (+)
RELEASE RELAY IN FUSE/JUNCTION BLOCK
Alarm  Input Wire:
BROWN / WHITE
Notes:
* Door Locks Require A Hard Chassis Ground To Operate, Must Use Relays; See Note #201 - Negative Pulse Door Lock Diagram.
Luis
Sound Waves
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
