door lock relay problem
mgeneral2000
Posted: January 08, 2004 at 8:50 PM / IP Logged
I recently bought actuators from e-bay to add to my alarm system. They are the type that have 2 wires and to lock and unlock the two wires need to switch polarity. I have tried the combinations for the relay hookups on the site and every time i hook the ground up to both 87a it blows the fuse on the +12 line. any advice would be greatly appricated.
dusted340
Member - Posts: 8
Posted: January 08, 2004 at 9:32 PM / IP Logged
What happens when you hook it up without a relay. could be a short in actuators.
If it works ok without relay check wires again, relays, switches
good luck
auex
Platinum - Posts: 5,041
Posted: January 08, 2004 at 10:02 PM / IP Logged
That would mean that you have +12V at pin 30? That is wrong, here is a diagram that will help, hopefully.
door lock relay problem - Last Post -- posted image.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
mgeneral2000
Posted: January 09, 2004 at 1:24 PM / IP Logged
I have it hooked up exactly like the above diagram, except i don't have the 87a's hooked up to a ground because every time i hook those up to a ground it blows the fuse. without it hooked up to the ground it works fine the currents alternate for lock and unlock, untill i hook up the wires to the actuators. After i hook up the wires to the actuator it shows a +12 reading on both 30's. any ideas? please help, thanks
xetmes
Silver - Posts: 586
Posted: January 09, 2004 at 1:32 PM / IP Logged
you most likely have  SPST relays instead of SPDT
auex
Posted: January 09, 2004 at 6:38 PM / IP Logged
That would explain it.
Sandungero24
Member - Posts: 44
Posted: February 25, 2004 at 8:23 PM / IP Logged
this diagram only applies if the "trigger" wires from the alarm provide a pulsed ground (-) to lock/unlock. If they provide a pulsed positive (+) instead, you will have to ground the opposite 85/86 terminal to allow the relay to work. Actually, my alarm allowed me to use either pulsed (-) or (+), I just chose to use the (-).
brnichols03
Member - Posts: 21
Posted: February 25, 2004 at 10:07 PM / IP Logged
get a DEI 451M door lock relay module on ebay
put the WHITE/ black and BROWN / black wires to ground
put the purple and PURPLE / black wire(s) to 12v
the remaining blue/black and GREEN/ black wires will be your lock and unlock output wires which can be ran to the actuators
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
