did I do something wrong?
ThurzNite
Member - Posts: 24
Posted: August 03, 2002 at 10:22 AM / IP Logged
I installed a ***** in my Altima. Everything went fine. Then the next day, I decide to redo the connections and tape the wires up for a cleaner/oem look. Now, it takes me 3 tries to start the car.
When ignition is in ACC, all electronics work. I crank and the starter goes for a split second, then shuts off, like there's no power. So I let go of the key and return to On. All electronics still ok. I crank again and nothing. However, if I turn back to ACC or Off, then try again, it'll crank a lil farther, then stop. The 3rd try is a charm and starts fine. This happens when the car is warm or cold, car runs and idles fine, all electronics work properly.
So could this be related to my re-wiring? I didn't change anything except the starter relay from normally open to nomally closed. But that shouldn't affect the starting. Any ideas? Thanx!
Jae
ThurzNite
Member - Posts: 24
Posted: August 04, 2002 at 5:32 PM / IP Logged
ok, figured it out. when i originally installed the alarm, i had it as normally open. then when I re-wired, I set it back to normally closed. Then I forgot to tell the brain that I changed it back to normally closed.
Jae
cpgoose
Gold - Posts: 1,098
Posted: August 04, 2002 at 7:27 PM / IP Logged
what's the difference in the two that it would affect
the starting? (I'm learning:)
Platinum - Posts: 12,488
Posted: August 05, 2002 at 7:26 AM / IP Logged
Hey cpgose: look at this diagram(  https://www.the12volt.com/relays/relays.asp ) for explaination of the N/O and N/C . If the starter is in the N/O then it will connect whatever is attached to pin 30 to 87 but when it is closed it will connect whatever is in pin 87a ( N/C ).
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
