Aftermarket Cruise Control Wiring
rickdog67
Posted: January 18, 2004 at 12:12 PM / IP Logged
I have a Cal Custom ZT 12 cruise control that has no instructions. I wondered if anybody knew how the wiring went. orange appears to be 12+ (switched?), it has in line fuse. Green appears to be negative, it has ring terminal on the end.Yellow has female spade connector insulated. 2 brown wires(possibly brake control?.Blue wire (possibly VSS?). Any help is appreciated...
rickdog67
Posted: January 18, 2004 at 12:22 PM / IP Logged
Also, this cruise controller has an ecs sensitivity adjuster, cyl (2468)switch, ign(STD,CD)switch, SPS Sensor (driveshaft, Tach)and a cruise sensitivity adjuster
fredisfound
Copper - Posts: 60
Posted: January 19, 2004 at 5:41 AM / IP Logged
Hi, the wiring colous are correct to what you said, The cyl switch is for how many cylinders, Ign for standard or electronic ignition, sps for speed sensor- driveshaft or tachometer. sensitivity is for when you get it working and you need fine adjustment.   ps. the yellow wire is tacho pulse connection. can be used on a manual gearbox car instead of a clutch override switch or for pulse setting. Hope this helps. I am still lost in Australia.....
rickdog67
Posted: January 19, 2004 at 4:18 PM / IP Logged
Thanks. I have an automatic, so does that mean yellow isnt needed? Also, does it matter which brown wire goes where(either positive or negative)?
rickdog67
Posted: January 19, 2004 at 9:07 PM / IP Logged
I think this cruise control is set up for driveshaft magnets, not vss which I have.
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
